IAP with Local,L3 DHCP
  • 1.  IAP with Local,L3 DHCP
    Posted Jul 09, 2016 06:13 PM
    First of all, I´m really newbe in Aruba. I´m testing an IAP in my house and I have some problems trying to achieve intenet access for the IPA clients, so I explain the context:
    - I have a cable router connected to internet and an internal net (192.168.1.0/24), in that internat net I have connected the IAP.
    - In the IAP I have created a "Local,L3" DHCP scope (192.168.2.0/24) and associated it to the VLAN 2
    - I have created an employee SSID and I have associated the VLAN 2 to that SSID.
    - I connect a client to that SSID and get and ip address from the VLAN 2 scope.
    - I try to access to internet (through the cable router of course) but it fail, even I can´t ping another device in the 192.168.1.0/24 net.
    - If I associate the VLAN 1 to the SSID instead of the VLAN 2 I can access to internet.
    I´m really missed and I don´t know what coud I be doing wrong. As I understand, "Local,L3" should be routing my VLAN 2.
    Please, could you help me. Thanks a lot.
  • 2.  RE: IAP with Local,L3 DHCP
    Posted Jul 11, 2016 05:16 AM
    Is vlan 2 on the uplink and is routing provided? Did you also check for any firewall settings blocking traffic between vlans?
    Kind regards
