Thanks, Marcus!
(my setup works "somewhat" but I feel unsure because I don't understand why it works ;) - below you find an excerpt from the debug output of the Radius)
> "you can create an entry for the VC IP address"
You mean in the general section? I did assign .209 here and I already use it for GUI management.
Or do you mean in the Radius definition? I did set a NAS IP address (.208) and this is part of the Rad request, but as you said this does not influence the IP origin (.65 = an IAP). What are these optional two fields for?
> "then enable Radius Proxy"
Where? Do you mean in the Radius definition (4 fields DRP-IP, -mask, -VLAN, - GW)? What should I put in there? Or am I in the wrong section?
New question: the below request comes again and again (with the ID increased by 1). Is this normal?
Thomas
Just FYI:
rad_recv: Access-Request packet from host 192.168.100.65 port 49161, id=105, length=213
User-Name = "John Doe"
NAS-IP-Address = 192.168.100.208
NAS-Port = 0
NAS-Identifier = "100"
NAS-Port-Type = Wireless-802.11
Calling-Station-Id = "68:96:7B:2F:8D:FC"
Called-Station-Id = "18:64:72:C0:64:66"
Service-Type = Login-User
Framed-MTU = 1100
EAP-Message = 0x020500061900
State = 0xb99bddaaba9ec435029562d4233ec38b
Aruba-Essid-Name = "Mitglied"
Aruba-Location-Id = "65-Revisionsklappe"
Aruba-AP-Group = "Instant-C0:64:D2"
Message-Authenticator = 0x1f23c9d07eb78e966a69bf25c2b7b860
