IAP1-5 stuck in reboot loop
  • 1.  IAP1-5 stuck in reboot loop
    Posted Dec 08, 2013 02:55 PM
    Below is output from the console. Ideas?
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU: AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM: 128 MB
    POST1: passed
    Copy: done
    Flash: 16 MB
    PCI: scanning bus 0 ...
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
    01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
    Net: eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot: 0
    Booting OS partition 0
    Checking image @ 0xbf100000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (6299544 bytes)
    Loading .data @ 0x81401fa0 (32 bytes)
    Clearing .bss @ 0x81401fc0 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing............................................................
    Aruba Networks
    ArubaOS Version 6.2.1.0-3.4.0.3 (build 40346 / label #40346)
    Built by p4build@cyprus on 2013-10-11 at 19:10:16 PDT (gcc version 4.3.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 120576k/131072k available (1687k kernel code, 10400k reserved, 625k data, 5484k init, 0k highmem)
    available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=27214848
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ................................................................................................................................................................................................................................................................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    .<6>lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    Testing TPM... Passed
    ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count 400
    AG7100: Max rx descriptor count 252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: d8:c7:c8:cd:b1:41
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    ag7100_ring_alloc Allocated 4800 at 0x8086a000
    ag7100_ring_alloc Allocated 3024 at 0x86e13000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0: phy not up carrier 1
    Writing 4
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    wifi uplink not present...
    Ethernet uplink not active yet
    AG7100: unit 0 phy is up...RGMii 100Mbps full duplex
    AG7100: pll reg 0x18050010: 0x1099 AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0x7ffef
    AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x12
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    Ethernet uplink active. Becoming Mesh Portal
    AP xml model 39, num_radios 2 (jiffies 17458)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    election init: rand=1d HZ=500
    setting bond0 as bridge child
    setting gre0 as split child
    notify asap_mod 3g no present...
    Starting watchdog process...
    Getting an IP address...
    Dec 31 16:00:35 udhcpc[813]: udhcpc (v0.9.9-pre) started
    Dec 31 16:00:35 udhcpc[813]: send_discover: pkt num 0, secs 0
    Dec 31 16:00:35 udhcpc[813]: Sending discover...
    Dec 31 16:00:35 udhcpc[813]: send_selecting: pkt num 0, secs 0
    Dec 31 16:00:35 udhcpc[813]: Sending select for 10.0.1.74...
    Dec 31 16:00:35 udhcpc[813]: Lease of 10.0.1.74 obtained, lease time 86400
    Dec 31 16:00:35 udhcpc[813]: DHCP OPT 43 deleted airwave config
    10.0.1.74 255.255.255.0 10.0.1.1
    Compressing all files in the /etc/httpd directory...
    ip_time_handler: Got ip and packets on bond0 Started master election 105-0
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    NTP Server not saved in flash... using default
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    ath_dev_attach: unable to attach hardware; HAL status 14
    wifi0: Base BSSID d8:c7:c8:5b:14:18, 8 available BSSID(s)
    bond0 address=d8:c7:c8:cd:b1:41
    br0 address=d8:c7:c8:cd:b1:41
    wifi0: AP type AP-105, radio 0, max_bssids 8
    wifi0: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
    ath_ahb: 0.9.4.5 (Atheros/multi-bss)
    Starting FIPS KAT ... Failed FIPS KAT.
    shutting down watchdog process (nanny will restart it)...
    <<<<< Welcome to the Access Point >>>>>
    Launching IAP CLI...
    process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    i am master now
    (19:46:40) !!! Init ---> Master
    asap_send_elected_master: sent successfully
    User: wifi0: Channel 157 cc=348 not found
    no bss chan on aruba000Break instruction in kernel code[#1]:
    Cpu 0
    $ 0 : 00000000 00000000 0000001a 80315940
    $ 4 : 80315940 00000001 00000007 00000002
    $ 8 : 808e3b24 ffffffff 0000003c 00000000
    $12 : 00000000 00000020 00000006 0000001f
    $16 : 85bdf828 85fd8000 857c8280 86f80280
    $20 : 85fd8289 857ca3e8 85fd8000 0000001a
    $24 : 00000000 c010140c
    $28 : 80520000 80521c00 0000a830 c09c72a4
    Hi : 000000e2
    Lo : 4dd56000
    epc : c09c72a4 ieee80211_ifattach+0x780/0x1188 [wlan] Tainted: P
    ra : c09c72a4 ieee80211_ifattach+0x780/0x1188 [wlan]
    Status: 1000d402 KERNEL EXL
    Cause : 5080c424
    PrId : 00019374
    Modules linked in: kat ath_pktlog wlan_scan_sta wlan_wep wlan_tkip wlan_ccmp ath_pci ath_dev spectrum dfs ath_rate_atheros ath_hal wlan asap_mod drvlog_mod ag7100_mod
    Process meshd (pid: 1083, threadinfo=80520000, task=80516ab8)
    Stack : 857ca3e8 857c8000 85bdf828 00000000 00000000 000005fa 0000001a 8545ae00
    857c8280 857ca3e8 86f80280 c09c962c 0000000d c0962f48 80521cb8 808e5144
    808d8710 8026fbdc 85bdf828 86a80000 857c8280 85fd8000 8540f410 86f80280
    8540f40c 00000000 86a83c8c c0963b20 80521c78 8012317c 00000000 857c8280
    00000000 80353000 8540f400 86a80000 00000000 c0a5c874 00000000 8021bf88
    Raw Call Trace:
    [<c09c962c>] ieee80211_beacon_alloc+0x25c/0x440 [wlan]
    [<c0962f48>] ath_set_ratecap+0x2fc/0xba0 [ath_pci]
    [<8026fbdc>] addrconf_add_linklocal+0x3c/0x80
    [<c0963b20>] wlan_iterate_vap_list+0x324/0x66c [ath_pci]
    [<8012317c>] __wake_up+0x30/0x58
    [<80353000>] vfs_caches_init_early+0x7c/0xa0
    [<c0a5c874>] ath_beacon_alloc+0xa8/0x214 [ath_dev]
    [<8021bf88>] netlink_broadcast+0x3ac/0x46c
    [<c0a627e0>] ath_dfs_war_task+0x520/0x930 [ath_dev]
    [<80215250>] rtmsg_ifinfo+0xe4/0x100
    [<c0965a0c>] ath_newstate+0x2c0/0x18f4 [ath_pci]
    [<80127d34>] printk+0x0/0x30
    [<c09eb504>] ieee80211_new_state+0xb8/0xf0 [wlan]
    [<8020c1d0>] dev_open+0xc8/0xd0
    [<c09ec73c>] ieee80211_init+0x408/0x450 [wlan]
    [<8013c25c>] autoremove_wake_function+0x0/0x4c
    [<801ff124>] sock_aio_write+0x58/0x70
    [<8020c168>] dev_open+0x60/0xd0
    [<8020ac8c>] dev_change_flags+0x70/0x154
    [<8020c6c8>] dev_ifsioc+0x20/0x470
    [<8024b230>] devinet_ioctl+0x2b0/0x710
    [<8020cf1c>] dev_ioctl+0x404/0x694
    [<80200d6c>] sock_ioctl+0x300/0x350
    [<80178fec>] do_ioctl+0x2c/0x78
    [<801ffc4c>] __sock_create+0x128/0x248
    [<8017930c>] vfs_ioctl+0x2d4/0x308
    [<80179390>] sys_ioctl+0x50/0x90
    [<802011f0>] sys_socket+0x24/0x48
    [<801136c4>] stack_done+0x20/0x3c
    Unwound Call Trace:
    [<c09c72a4>] ieee80211_ifattach+0x780/0x1188 [wlan]
    Code: 24427d34 0040f809 24844ad0 <0200000d> 3c02801c 00002821 02002021 244205c0 0040f809
    wdt_ar7100_refresh: Enabling kernel refresh of watchdog.
    Time Sun Dec 8 19:46:52 2013: Flash erase @ 0xbff70000
  • 2.  RE: IAP1-5 stuck in reboot loop
    MVP
    Posted Dec 08, 2013 04:04 PM
    Is this IAP factory default or previously configured? Is this the only IAP in the cluster? I noticed it said Master so I assume it's the first you've powered up?
  • 3.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 08, 2013 07:33 PM
    It looks like the IAP is not able to get an IP ?
  • 4.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 11, 2013 08:52 AM
    It is getting an IP, 10.0.1.74. The web interface is very briefly available, sometimes even long enough to log in, but not more than a few seconds before rebooting.
  • 5.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 11, 2013 10:47 AM
    Could you get into APBOOT via the console connection , run the command 'mfginfo' and share with us the result?
  • 6.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 11, 2013 10:53 AM
    Manufacturing info:
    System S/N : BE0193387
    Date Code : 110411
    Base MAC : d8:c7:c8:cd:b1:41
    MAC Count : 1
    CPU Assembly : 0YXG0KP0
    CPU Major Rev : SY
    CPU Brd Variant : 00
    CPU Board S/N : 0G1AR2473
    Country Code : US
    PROM Format : 1
    Checksum : b0
  • 7.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 11, 2013 08:55 PM
    Do you have other IAP105s in your network? Is this the only AP that is crashing?
    Yan
  • 8.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 12, 2013 03:22 PM
    I have another AP it does not crash.  It also is unconfigured.  At one time I had 4 of these setup for a evaluation.  I only have two of them left and this one for some reasom crashes on boot.  They have both been factory reset.  I have tried several different firmware images as well.
  • 9.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 12, 2013 06:54 PM
    Is there a possibility of swapping the location of the two APs to eliminate the possibility of a hardware issue?
  • 10.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 11, 2013 08:51 AM
    This is factory default, yes at the time it was the only AP.  I have another that boots up just fine, but I have not configured that one either.
  • 11.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 08, 2013 07:38 PM
    Looks like option 43 is configured in your DHCP server. Are you trying to
    bring it up fresh or pull a config from AirWave?
  • 12.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 11, 2013 08:53 AM
    Boot up fresh, as far as I can tell I don't have option 43 configured in my DHCP server.
  • 13.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 11, 2013 01:30 AM
    which country-code we run? It seemed this IAP running with a country-code we not support.
  • 14.  RE: IAP1-5 stuck in reboot loop
    Posted Dec 11, 2013 08:55 AM
    How do I determine country code?
