IAP103 broadcast filtering and HP Airprint
  • 1.  IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 10:43 AM
    Hello everyone!
    Please help, I just installed 4 x IAP103. Network is working fine, but we have a HP Printer that we use via Airprint. To enable this i know broadcast filtering has to be disabled end under more, services, airgroup settings i have to select allow all to use airprint. When i disable broadcast filtering, the network becomes instable, drops speed 70% and clients randomly disconnect. Anyone got a workaround?
  • 2.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 10:46 AM
    You should be able to enable broadcast filtering and use Airprint if it is allowed in Airgroup.
  • 3.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 11:24 AM
    Hi Colin,
    No, when only airprint is activated in airgroups the printer is not visible in the network...
  • 4.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 11:29 AM
    Type "show airgroup blocked-queries" to see if your printer is being blocked somehow..
  • 5.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 11:38 AM
    Uhmmm... maybe a dumb question, but where do i type this?
  • 6.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 12:28 PM
    To see if mdns printer queries are being blocked for some reason, either from your client or the printer.
  • 7.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 12:50 PM
    I understand, but where can i see this/search this?
  • 8.  RE: IAP103 broadcast filtering and HP Airprint
    You would SSH into the Virtual Controller and execute it.
  • 9.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 02:26 PM
    I'm sorry Colin, I'm not too technical, i don't understand what to do... Can you explain?
  • 10.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 20, 2017 08:04 PM
    Allright.
    Click on the Airgroup Bar and see if you see the printer as a client or a server.
  • 11.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 21, 2017 11:50 AM
    Hi Colin,
    Sorry, i had to work all day so i couldn't respond earlier. I'm logged in now and this is what i see... Don't see the printer here. The printer is visible in the main screen by IP number but not devicename. What to do next?
  • 12.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 21, 2017 12:26 PM
    Enable Bonjour in your settings, please.
  • 13.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 21, 2017 12:55 PM
    Done. It works. It looks like the network is a little less stable but i'm gonna test for a day. I'll get back to you!
  • 14.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 21, 2017 01:03 PM
    You should have Broadcast Filter ARP on all of your SSIDs in advanced, as well.
  • 15.  RE: IAP103 broadcast filtering and HP Airprint
    Posted Feb 24, 2017 03:26 AM
    Thanx Colin,
    You're the best. Network is working perfect now!
