IAP103 roaming/hand off iPads
  • 1.  IAP103 roaming/hand off iPads
    Posted Sep 20, 2014 08:50 AM
    I have 2 iap103 and will have about 5 iPads on the network.
    What settings do I need to enable on the iap103 to get the iPads to handoff seamlessly between access points?
    Do I need to setup the network as personal or enterprise to accomplish this roaming/hand off between access points?
    These iPads will be the backbone of my home's automation and lighting system, and I need to be able to pick up an ipad and walk around the house and have it automatically connect to the best AP.
    I just need some guidance as to what settings need to be used to allow this seamless roaming/handoff.
    Thanks for any help
  • 2.  RE: IAP103 roaming/hand off iPads
    Posted Sep 21, 2014 07:52 AM
    So long as the IAPs are operating in the same cluster, there should be nothing further you need to do.
  • 3.  RE: IAP103 roaming/hand off iPads
    Posted Sep 21, 2014 09:04 PM
    Do you see all the APs in the web UI? If so you should not have to do anything. Are you experiencing any specific roaming difficulties?
    Yan
    Sent from my iPhone
