IAP104 fails to convert to Mobility Controlled
  • 1.  IAP104 fails to convert to Mobility Controlled
    Posted Jan 22, 2013 12:33 PM
    I am gtrying to convert an IAP to work from a Controller, However, although it claims it is connecting to the controller I see no proof of this and then an error message returns "Image Verify Failed".   The controller is running 6.1.2.3 is there something I am missing?
  • 2.  RE: IAP104 fails to convert to Mobility Controlled
    Posted Jan 22, 2013 02:05 PM
    The IAP needs to be running 3.0 or higher.
    The controller needs to run AOS 6.1.4.x or AOS 6.2.0.2.
  • 3.  RE: IAP104 fails to convert to Mobility Controlled
    Posted Jan 22, 2013 02:54 PM
    On the download page the general availability is only upto 6.1.3.6 . Am I just not getting all versions or is this not available yet.  I can only get 6.2 releases in the early release category. I wouldn't want to put this into a customer environ yet.
  • 4.  RE: IAP104 fails to convert to Mobility Controlled
    Posted Jan 22, 2013 09:31 PM
    6.1.4 was a limited release / technology release.   You need to open a case with TAC to get a copy.
    Between 6.1.4 and 6.2.0.2, and above, I would go with 6.2.0.2.
