IAP105 & 115 not giving DHCP to clients
  • 1.  IAP105 & 115 not giving DHCP to clients
    Posted Sep 16, 2014 10:52 AM
    Hi All,
    we had a set of 8 IAP105s that where working great, we then added 8 new 115s and no clients apart from guest get DHCP.
    i found the installers had not upgraded all the APS to the same firmware version, so i have upgraded them all to the same version 6.3.1.8-4.0.0.7_44641
    Setup:
    > This is a flat layer 2 setup so no vlans to add into the mix.
    > All 16 appear in cluster
    > Tried DHCP on lan ports all fine
    Any advice would be great
  • 2.  RE: IAP105 & 115 not giving DHCP to clients
    Posted Sep 16, 2014 04:53 PM
    Wierd. Are you using the "Assigned by virtual controller" or VC Assigned option? There is this for the defualt, and several other places to define DHCP. The basic setup would be to include a dhcp pool in the System settings by clicking on System > Show advanced options > DHCP. This should support up to 512 clients.
    Other dvanced DHCP configurations support up to 2048, you can configure these in the More > DHCP section...
  • 3.  RE: IAP105 & 115 not giving DHCP to clients
    Posted Sep 22, 2014 07:01 AM
    This was fixed by the server having two IPs but NPS only being bound to one.
