IAP105 Bridge Wireless
  • 1.  IAP105 Bridge Wireless
    Posted Mar 06, 2014 09:46 AM
    Hi ALL,
    does IAP 105 support bridge wired traffic through mesh mode?
    I'm trying to configure it as described in the following note, but it doesn't work.
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1666
    I have my Instant Cluster (2 x IAP105 running 6.2.1.0) and it works perfectly.
    I enable the Eth0 bridging on  1 IAP105, I reboot it and I disconnected it from the network.
    After these operations the AP reboots continuosly and it doesn't work.
    Gian
  • 2.  RE: IAP105 Bridge Wireless
    Posted Mar 06, 2014 04:30 PM
    I've tested it with latest code at IAP105. There were some improvements I guess :) Could you upgrade to 4.0?
    Many regards,
    Marek
  • 3.  RE: IAP105 Bridge Wireless
    Posted Mar 07, 2014 03:06 AM
    I have investigated about the issue... the problem is the mesh.
    If I disconnect the IAP from the network (before enabling the bridge in the wired eth), it is not able to contact the other IAP via mesh.
  • 4.  RE: IAP105 Bridge Wireless
    Posted Mar 07, 2014 03:33 AM
    Have you enabled Extended SSID? If so, please disable, otherwise MESH does not work.
    HTH
