IAP115 - Radio down
  • 1.  IAP115 - Radio down
    Posted Apr 29, 2014 06:53 AM
    Hi guys,
    I have a strange issue (with workaround), and my customer demand explanation with this. Whenever we chose our Country to Malaysia (after initial factory reset ), the radio is down and I can't see default "instant" SSID. The workaround is to perform another factory reset, and we chose the Country to Japan and the radio is up, we can see "instant" SSID.
    Is this something wrong? The firmware we have here is latest 6.3.1.0-4.0.0
    When I perform "show run" on both Country Code (MY and JP) and compare them, they look identical except for this line.
    Japan
    virtual-controller-country JP3
    Malaysia
    virtual-controller-country MY
    Is this a firmware issue or known issue? Any help is much appreciate.
    Ryan
  • 2.  RE: IAP115 - Radio down
    Posted Apr 29, 2014 07:28 AM
    I had a similar issue and what I noticed was that the instant network got disable , if you do a show network you will see that.
    But to try to enable it again its a pain.
  • 3.  RE: IAP115 - Radio down
    Posted May 05, 2014 10:09 AM
    Escalated to TAC, the newer version 6.3.1.4-4.0.0.5 fixed the isue.
