IAP205 - How to configure IP reservation to wireless client?
  • 1.  IAP205 - How to configure IP reservation to wireless client?
    Posted Apr 11, 2016 07:11 AM
    I have an IAP205 which is connected to a ADSL NTU (very simple setup)...I use the IAP to dish out IP address to all the wireless client.
    How do I configure IP reservation in the IAP so that some of the wireless client will get the same IP whenever they get connected to the IAP?
    I check the "DHCP server" menu but can't find any configuration (only those DHCP scoping)....Is IP reservation hidden somewhere?
  • 2.  RE: IAP205 - How to configure IP reservation to wireless client?
    Posted Apr 11, 2016 08:49 AM
    The internal DHCP server does not support reservations in IAP.
  • 3.  RE: IAP205 - How to configure IP reservation to wireless client?
    Posted Apr 11, 2016 05:31 PM
    Thanks...
    How about can I exclude certain range of IP in the IAP so that it would
    assign that range? Ie. We will key in the static IP in those laptops...
  • 4.  RE: IAP205 - How to configure IP reservation to wireless client?
    Posted Apr 11, 2016 05:35 PM
    You can configure a network range for clients ;  http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/DHCP_conf/DHCP Config.htm?Highlight=dhcp
  • 5.  RE: IAP205 - How to configure IP reservation to wireless client?
    Posted Apr 11, 2016 09:22 PM
    I took a look at the URL but it doesn't solve my problem....The fields only
    allow me to put in the subnet and mask. It didn't have any exclude field..
    For example, I have 3 wireless printers with the static IP(10.1.1.201,
    10.1.1.202, 10.1.1.203) configure in them. How do I ensure the IAP does not
    dish out these 3 IPs when a wireless client connected to it?
    In Cisco, they have this "ip dhcp exclude xxx" command to exclude IP from
    the DHCP server...How do I do that in IAP?
  • 6.  RE: IAP205 - How to configure IP reservation to wireless client?
    Posted Apr 11, 2016 09:46 PM
    You are right.  You cannot exclude anything with the virtual AP assigned DHCP server.  It is really intended for just guest networks...
