IAP205H LEDs when used as a RAP - query
  • 1.  IAP205H LEDs when used as a RAP - query
    Posted Apr 19, 2017 08:27 PM
    Hi
    We have a couple of IAP205H that we have converted to RAPs. The conversion goes fine, the devices connect to our controllers fine, the SSIDs are broadcast fine, the users can connect fine and the traffic runs fine.  But... the "status" LED on the device won't go green.  It blinks green when the RAP is booting, then when it makes its connection to the controller, the LED goes RED.  The paperwork that come with devices says that red is bad, green is good, but we can not get it to go solid green.
    Any ideas?
  • 2.  RE: IAP205H LEDs when used as a RAP - query
    Posted Apr 19, 2017 08:29 PM
    Do you have a picture of it?
  • 3.  RE: IAP205H LEDs when used as a RAP - query
    Posted Apr 19, 2017 10:20 PM
    Here is the RAP after the boot sequence has completed.
  • 4.  RE: IAP205H LEDs when used as a RAP - query
    Posted Apr 19, 2017 10:36 PM
    Oh yea, and firmware is  ArubaInstant_Taurus_6448-4246_58505
  • 5.  RE: IAP205H LEDs when used as a RAP - query
    Posted Apr 19, 2017 11:08 PM
    That does not look "red" in the picture.  It could be amber-solid:
  • 6.  RE: IAP205H LEDs when used as a RAP - query
    Posted Apr 19, 2017 11:21 PM
    Nah, its red alright. Just camera colour mis-match
