IAP207mesh points rebooting by reason "mesh link BAD. rebooting mesh point by sapd"
  • 1.  IAP207mesh points rebooting by reason "mesh link BAD. rebooting mesh point by sapd"
    Posted Nov 21, 2017 03:43 PM
    We have about 4 IAP207 mesh points connecting to mesh portal.
    The points are rebooting with reason
    Advise what can be possible reasons?
    When two nodes IAP(that is mesh point and mesh portal), I usually set on on a static channel and set at some optimum power depending on the distance.
    Can i still set all the APs in same channel for 5Ghz, and setup a mesh(in this case of 1 portal and 4 points, all are AP207).?
  • 2.  RE: IAP207mesh points rebooting by reason "mesh link BAD. rebooting mesh point by sapd"
    Posted Nov 21, 2017 03:52 PM
    How far apart are the access points?
  • 3.  RE: IAP207mesh points rebooting by reason "mesh link BAD. rebooting mesh point by sapd"
    Posted Dec 28, 2017 07:29 AM
    mesh links became statble, after removing the non-dfs channels, from the valid channels.
    The installation was found to be near to the airport.
