IAP214 vs IAP215 External vs Internal Anntenna
  • 1.  IAP214 vs IAP215 External vs Internal Anntenna
    Posted Nov 10, 2014 04:27 PM
    Hello Everybody, hope your monday has gone well,
    I was curious what the pros and cons were for IAP214s vs IAP215s, if someone could breifly go over the benefits of each,
    When should one consider an IAP214 external antenna AP over an IAP215 internal antenna AP
  • 2.  RE: IAP214 vs IAP215 External vs Internal Anntenna
    Posted Nov 11, 2014 11:56 AM
    you use IAP 214 if you want to use external antenas to get more distance to cover, because you can change the type of antena depends of your enviroment. or redirect the antena to an specific place.
    with iap 215 the antenas are inside the AP so you just have to put the ap in the best position to cover all place.
