IAP225 power and radio confirmations
  • 1.  IAP225 power and radio confirmations
    Posted Apr 02, 2014 04:54 PM
    I have an IAP225 that is connected to a Cisco 4506E switch. The IAP225 is power by POE 802.3at (30watts). What i am seeing is slow connectivity during my speed test (we have a 100Meg metro circuit to the internet). I am wondering where in the IAP225 i can find the radio status to make sure i am not being throttle to 1×3:1SS mode, eventhough i'm am providing it with 30Watts of POE.
    When i connect to my Motorola AP7131, i can get about 60Mbps down and 55Mbps up. With the IAP225 it seem to be throttle to 10Mbps down and 10Mbps up.
    The IAP225 and the Motorola AP7131 is setup and connect the same way. AP -->Switch-->Router--100Mbps Circuit (Internet).
  • 2.  RE: IAP225 power and radio confirmations
    Posted Apr 02, 2014 04:56 PM
    You can run:
    show ap association
  • 3.  RE: IAP225 power and radio confirmations
    Posted Apr 02, 2014 05:45 PM
    The "show ap association" command will only so you the client capability not what mode the IAP225 is operating at.
  • 4.  RE: IAP225 power and radio confirmations
    Posted Apr 02, 2014 05:52 PM
    Sorry. Misunderstood your question.
     show ap debug system-status | include ic_num_rx_chain=
  • 5.  RE: IAP225 power and radio confirmations
    Posted Apr 02, 2014 06:26 PM
    Thanks bud. For some reason when i input that command, i don't see it.
  • 6.  RE: IAP225 power and radio confirmations
    Posted Apr 02, 2014 07:47 PM
    Try this one , is similar to the one tim suggested
