IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
  • 1.  IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 21, 2014 05:24 PM
    Have just deployed a bunch of 20 IAP225 that is using Clearpass for the authentication.  The customer is reporting that connectivity is lost on Windows devices, with the yellow exclamation, and connection to exchange server lost.  This happens about 2 minutes after connecting and will last about a min or so, but it keeps happening every 3-5 mins.
    I don't have direct access to troubleshoot, but here are a couple of things on how it is configured.
    • vlan is static with gateway being the core switch.
    • 80 MHz channels enabled (not sure what band users connected on though)
    • client-match enabled
    • 802.11r enabled
    • RFC3576 enabled on auth-server profile with accounting mode as 'authentication'.
    I will be troubleshooting this with the customer further and looking at access tracker on Clearpass as well.  Normally I would put this sort of thing down to their own network, but this is my first IAP225 with Clearpass so I'm keeping an open mind.
    I'm thinking to disable client-match to see how it looks then as well.
    Has anyone else had issues such as this or any suggestions?
  • 2.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 21, 2014 06:11 PM
    What version of Instant?   There were some improvements for IAP-225s fixed in 6.3.1.2-4.0.0.3.     If you are already on this release, please PM me.
  • 3.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 22, 2014 03:07 AM
    Currently 6.3.1.1-4.0.0.1, but I'm going to disable client-match and 80MHz channels as a first step.  Will let you know how it goes.
  • 4.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 22, 2014 04:05 AM
    We have the same issue with windows clients, though not in every 3-5 minutes, but multiple times during the day.
    We are not using ClearPass, just WPA2-PSK and we have 802.11r and client-match disabled. (there were more problems while these settings was enabled).
    We are on 4.0.0.3
  • 5.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 22, 2014 05:56 AM
    Config below.
    version 6.3.1.0-4.0.0
    virtual-controller-country GB
    virtual-controller-key <key>
    name VC
    organization <org>
    virtual-controller-ip 192.168.103.245
    terminal-access
    ntp-server 192.168.100.251
    clock timezone London 00 00
    clock summer-time BST recurring last sunday march 02:00 last sunday october 02:00
    rf-band all
    dynamic-radius-proxy
    ams-ip 192.168.100.56
    ams-key <key>
    ams-identity <identity>
    allow-new-aps
    arm
     wide-bands 5ghz
     80mhz-support
     min-tx-power 12
     max-tx-power 18
     band-steering-mode prefer-5ghz
     air-time-fairness-mode preferred-access
     client-aware
     scanning
     client-match slb-mode 3
    internal-domains
     domain-name <domain>
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    user mickc 00dc25953325a1608158f07740625476d1a118620dd9f91d portal
    mgmt-user admin <password>
    wlan access-rule Guest
     index 0
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
     rule 192.168.0.0 255.255.0.0 match any any any deny
     rule any any match any any any permit
     bandwidth-limit peruser downstream 512
     bandwidth-limit peruser upstream 512
    wlan access-rule default_wired_port_profile
     index 1
    wlan access-rule wired-instant
     index 2
     rule 192.168.102.41 255.255.255.255 match tcp 80 80 permit
     rule 192.168.102.41 255.255.255.255 match tcp 4343 4343 permit
    wlan access-rule Guest-logon
     index 3
     rule 192.168.100.57 255.255.255.255 match tcp 80 80 permit
     rule 192.168.100.57 255.255.255.255 match tcp 443 443 permit
     rule any any match icmp any any permit
     rule any any match any any any deny
     bandwidth-limit peruser downstream 256
     bandwidth-limit peruser upstream 256
    wlan access-rule Corp
     index 4
     rule 192.168.0.0 255.255.0.0 match any any any permit
    wlan access-rule MDM-Quarantine
     index 5
     vlan 154
     captive-portal external profile Quatantine
     rule 192.168.100.57 255.255.255.255 invert tcp 80 80 permit
     rule 192.168.100.57 255.255.255.255 invert tcp 443 443 permit
    wlan access-rule MDM-ipad
     index 6
    wlan access-rule MDM-Employee-device
     index 7
    wlan access-rule MDM-Corporate-device
     index 8
    wlan access-rule BYOD
     index 9
     captive-portal external profile BYOD
    wlan access-rule Machine
     index 10
    wlan access-rule Wifi
     index 11
     index 12
    wlan ssid-profile Guest
     disable
     index 0
     type guest
     essid Guest
     opmode opensystem
     max-authentication-failures 0
     vlan guest
     auth-server clearpass
     set-role-pre-auth Guest-logon
     set-role Aruba-User-Role value-of
     rf-band all
     captive-portal external profile Guest
     mac-authentication
     mac-authentication-delimiter :
     dtim-period 2
     inactivity-timeout 1000
     broadcast-filter all
     radius-accounting
     radius-interim-accounting-interval 10
     g-min-tx-rate 11
     a-min-tx-rate 12
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 20
     max-clients-threshold 64
    wlan ssid-profile Corp
     disable
     index 1
     type employee
     essid Corp
     opmode wpa2-aes
     vlan 150
     rf-band all
     captive-portal disable
     dtim-period 2
     broadcast-filter arp
     radius-accounting
     radius-interim-accounting-interval 20
     g-min-tx-rate 11
     a-min-tx-rate 12
     multicast-rate-optimization
     dynamic-multicast-optimization
     dot11r
    wlan ssid-profile Wifi
     enable
     index 2
     type employee
     essid Wifi
     opmode wpa2-aes
     vlan 150
     auth-survivability
     rf-band all
     dtim-period 2
     radius-accounting
     g-min-tx-rate 11
     a-min-tx-rate 12
     enable
     index 3
     type guest
     essid Guest
     opmode opensystem
     vlan 154
     rf-band all
     mac-authentication
     dtim-period 2
     radius-accounting
     g-min-tx-rate 11
     a-min-tx-rate 12
    auth-survivability cache-time-out 24
    wlan auth-server clearpass
     ip 192.168.100.57
     port 1812
     acctport 1813
     key <key>
     rfc3576
     cppm-rfc3576-port 5999
    wlan captive-portal
     background-color 13421772
     banner-color 16750848
     banner-text "Welcome to Guest Network"
     terms-of-use "This network is in development."
     use-policy "Do not ask for a username/password.  In development."
     authenticated
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
     auto-whitelist-disable
     https
    wlan external-captive-portal Guest
     server 192.168.100.57
     port 443
     url "/guest/landing.php/Guest.php"
     auth-text ""
     https
    wlan external-captive-portal Quatantine
     port 80
     url "/guest/landing.php/Quarantine.php"
     auth-text ""
    wlan external-captive-portal BYOD
     port 80
     url "/guest/landing.php/BYOD.php"
     auth-text ""
     port 443
     auth-text ""
     https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids classification
    ids
     wireless-containment none
    wired-port-profile wired-instant
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
  • 6.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 22, 2014 08:02 AM
    I had same issues with iAP105 on 4.0.0.2 and reverted back to 3.4.0.6 and the connectivity issue disapeared.
  • 7.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 22, 2014 11:40 AM
    With 225s, minimum firmware version is 4.0, 3.4 won't work on an IAP-225
  • 8.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 28, 2014 02:45 PM
    There was a duplicate ip for the gateway which I guess was the primary cause of the issues.  Intel Proset software I think as well was doing funny things.
    I had already disabled client-match, so unclear if that would have caused issues anyway.  Hopefully we'll get a chance to enable again to evaluate.
  • 9.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 28, 2014 03:08 PM
    Wow.  That is notoriously difficult to track down.  Glad to hear you worked it out.
  • 10.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted Jan 29, 2014 03:50 AM
    Actually it was pretty easy with a packet capture on a wired client.
    :smileyhappy:
  • 11.  RE: IAP225 (with Clearpass) - Windows laptops loosing connectivity every few minutes
    Posted May 13, 2014 04:55 PM
    Customer has enabled client-match again to resolve some stubborn sticky clients. So far everything is still good.
