IAP274 External antenna selection
  • 1.  IAP274 External antenna selection
    Posted Jul 16, 2017 03:26 AM
    Hi guys,
    I usually offer IAP275 for outdoor integrated OMNI antenna while IAP277 for outdoor integrated directional antenna. However some clients prefer deploying external antenna in which I’m having difficulty in recommending and consolidating these antennas according to purpose.
    Below is my attempt to sort them according to docs.Any corrections or suggestions are greatly appreciated.
    *directional antenna, (check datasheet for beamwidths)*
    2.4Ghz for client serving like street, spot coverage etc
    ANT-2x2-2314
    http://www.arubanetworks.com/assets/ds/DS_ANT-2x2-2314.pdf
    2.4/5Ghz sector wi-fi converage
    ANT-3x3-D608
    http://www.arubanetworks.com/assets/ds/DS_ANT-3x3-D608.pdf
    ANT-3x3-D100
    http://www.arubanetworks.com/assets/ds/DS_ANT-3x3-D100.pdf
    5Ghz P2P connections
    ANT-2x2-5314 (p2P)
    http://www.arubanetworks.com/assets/ds/DS_ANT-2x2-5314.pdf
    ANT-3x3-5712 (point to multipoint) mesh connections
    http://www.arubanetworks.com/assets/ds/DS_ANT-3x3-5712.pdf
    2.4Ghz 802.11nMIMO mesh link applications
    ANT-2x2-2714
    http://www.arubanetworks.com/assets/ds/DS_ANT-2x2-2714.pdf
    My question is how to determine the required qty of antenna per AP and its lightning arrestors?
    I’m also referring to AP270 ordering guide
    http://www.arubanetworks.com/assets/og/OG_AP-270Series.pdf
  • 2.  RE: IAP274 External antenna selection
    Posted Jul 16, 2017 11:46 PM
    A quick note, generally speaking we don't recommend any high gain antennas for client coverage, the 2x2-2314/2x2.2714 are mostly for limited mesh purposes in countrys where 5Ghz is disallowed.
    To the question on the number of antennas, the 274 is a 3x3 AP, which means there are three connectors per radio. You CAN use a 2x2 antenna on a 3x3 AP, you just put the antenna on ANT0/ANT1, and have to put a 50 ohm terminator on the unused connector ANT2 for whatever radio the 2x2 antenna is placed on.
  • 3.  RE: IAP274 External antenna selection
    Posted Oct 11, 2018 11:38 AM
    Hi Jerod,
    I'm trying to use the ANT 2005 + ANT 5005 for an outdoor  site survey. The IAPs have static IPs so I can access them if need be onsite. However when I set the antenna gain , I get prompted to reboot the AP which Im able to do from the maintenance tab. However after the AP boots back up , I see the antenna gain set back to 0 almost as if the AP isnt accepting the values. I tried on both the 274s - 1 which has 6 antennas plugged into it and the other with no antennas plugged into it. Need some help on this.
    Thanks, Abdul
  • 4.  RE: IAP274 External antenna selection
    Posted Nov 07, 2018 09:27 PM
    Have you created your SSID yet? With IAP, if the default SetMeUp or Instant SSID is still there, it defaults the AP.
