Hi Guys,
I'm trying to get an IAP3 working with a E160 dongle in the UK on O2 but seem to be having a problem with it.
Is there a specified firmware version that I need to use on the dongle.
I have tried entering the info from the below but when i plug in the dongle the aruba just keeps rebooting.
The Aruba is using FW 6.2.1
Si
http://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/16874/1/RFE1381-Configuring%20Cellular%20Modems%20for%20Aruba%20Remote%20APs%20(3).pdf
usb_user=O2web usb_passwd=password usb_type=option (2)
usb_dev=0x12d11003
usb_dial=ATDT*99***1# usb_init=AT+CGDCONT=1,'IP','mobile.o2.co.uk'
Please try to connect your modem to PC or (best option) to Linux. Then check USB Device ID. Sometimes modem vendors change ID parameters. I had the same with E173.
when i check the diagnostics for the modem it says its deffinitely an E160 Revision 11.609.10.02.432
Hi marqs,
you have your e173 settings by hand , have also some o2 branded one now with huawei firmware , still in hybrid mode. im digging into another 3G modem parameters document too , see attached - this is suitable to the other one you posted.
https://dl.dropboxusercontent.com/u/67416983/3g_modem_parameters-1.pdf
thanks
ben
