IAP318, IAP315 AOS 8.4.2 flapping on 2930M
  • 1.  IAP318, IAP315 AOS 8.4.2 flapping on 2930M
    Posted Jul 31, 2019 10:59 AM
    I have AccessPoints (318, 315) connect on 2930M Poe Switches (Stacking), Mobility Master and Mobility Controller (7210).
    I see on the mobilty master that some access points online and offline, online and offline.
    on the 2930 switch I can see
    I 07/31/19 16:55:54 00076 ports: ST2-CMDR: port 3/39 is now on-line
    I 07/31/19 16:55:54 00076 ports: ST2-CMDR: port 3/19 is now on-line
    I 07/31/19 16:55:54 00076 ports: ST2-CMDR: port 2/33 is now on-line
    I 07/31/19 16:55:54 00076 ports: ST2-CMDR: port 2/16 is now on-line
    I 07/31/19 16:55:52 00076 ports: ST2-CMDR: port 3/6 is now on-line
    I 07/31/19 16:55:52 00435 ports: ST2-CMDR: port 2/33 is Blocked by STP
    I 07/31/19 16:55:52 00435 ports: ST2-CMDR: port 3/39 is Blocked by STP
    I 07/31/19 16:55:52 00435 ports: ST2-CMDR: port 3/19 is Blocked by STP
    I 07/31/19 16:55:52 00435 ports: ST2-CMDR: port 2/16 is Blocked by STP
    I 07/31/19 16:55:50 00435 ports: ST2-CMDR: port 3/6 is Blocked by STP
    I 07/31/19 16:55:49 00077 ports: ST2-CMDR: port 2/33 is now off-line
    I 07/31/19 16:55:49 00077 ports: ST2-CMDR: port 2/16 is now off-line
    I 07/31/19 16:55:49 00077 ports: ST2-CMDR: port 3/39 is now off-line
    I 07/31/19 16:55:49 00077 ports: ST2-CMDR: port 3/19 is now off-line
    I 07/31/19 16:55:42 00077 ports: ST2-CMDR: port 3/6 is now off-line
    How can I troubleshoot why the APs flapping?
    Greetings
  • 2.  RE: IAP318, IAP315 AOS 8.4.2 flapping on 2930M
    MVP EXPERT
    Posted Jul 31, 2019 11:28 AM
    Looks like Spanning Tree (STP) is blocking some ports, can you confirm these are the ports which the APs terminate on?
    What is the current spanning tree configuration within your deployment?
  • 3.  RE: IAP318, IAP315 AOS 8.4.2 flapping on 2930M
    Posted Jul 31, 2019 12:10 PM
    Also if there is any mesh, ensure there's no loops.
  • 4.  RE: IAP318, IAP315 AOS 8.4.2 flapping on 2930M
    Posted Jul 31, 2019 12:43 PM
    no mesh configuration - on the 2930 switch (3x stacking) there are only APs connected
    STP is MST
     show spanning-tree
     Multiple Spanning Tree (MST) Information
      STP Enabled   : Yes
      Force Version : MSTP-operation
      IST Mapped VLANs : 1-4094
      Switch MAC Address : 8030e0-eb2cca
      Switch Priority    : 32768
      Max Age  : 20
      Max Hops : 20
      Forward Delay : 15
      Topology Change Count  : 4
      Time Since Last Change : 4 hours
      CST Root MAC Address : 548028-754700
      CST Root Priority    : 0
      CST Root Path Cost   : 2000
      CST Root Port        : 2/A1
      IST Regional Root MAC Address : 8030e0-eb2cca
      IST Regional Root Priority    : 32768
      IST Regional Root Path Cost   : 0
      IST Remaining Hops            : 20
      Root Guard Ports     :
      Loop Guard Ports     :
      TCN Guard Ports      :
      BPDU Protected Ports : 1/1-1/48,2/1-2/48,3/1-3/48
      BPDU Filtered Ports  :
      PVST Protected Ports :
      PVST Filtered Ports  :
      Root Inconsistent Ports  :
      Loop Inconsistent Ports  :
    yes STP is working and block but why?  according the log it shows for me then the aps are connect to the port and unconnect
