IAP335 still not joining current group
  • 1.  IAP335 still not joining current group
    Posted Oct 26, 2016 09:54 AM
    ok these IAP 335's are becoming an ordeal..  here is a little background.. i have a mix of IAP 105's 135's and 225's and im trying to add new IAP 335's to the mix which are on firmware 6.5.   i was told that i needed to upgrade the firmware on the older devices in order for the IAP335's to join.    so i went from   version 6.4.2.6-4.1.3.0_54915  to  6.4.4.4-4.2.3.2_54910  on all of my IAP's..  i still find that the IAP335's are still not joining. the power/system light blink green but never go ready..    i cant find the same firmware version for the 335's so i can downgrade them ..  i see the firmware for the 325 but not 335..    can anyone help ..    thanks
  • 2.  RE: IAP335 still not joining current group
    Posted Oct 26, 2016 10:25 AM
    AP 335s have a minimum requirement of Instant 4.3.0.0.  Please PM me  if you need me to send that to you for your AP335s and other platforms...
  • 3.  RE: IAP335 still not joining current group
    Posted Oct 26, 2016 12:43 PM
    Okay.  The only issue that I see is that the AP-105 and AP135 is not supported for Instant 4.3.x.x and above.  You have to choose between supporting 335s or 135s and 105s in the same cluster.  http://www.arubanetworks.com/support-services/end-of-life/#AccessPoints
  • 4.  RE: IAP335 still not joining current group
    Posted Oct 26, 2016 01:08 PM
    Ah ok.    thanks for your help..  i guess ill keep these until i can replace all of the 105's and 135's..
