IAP387 Reviewing 60 gHz Radio
  • 1.  IAP387 Reviewing 60 gHz Radio
    Posted Jul 22, 2019 01:15 PM
    I have AP387 in instant cluster providing mesh link peer to peer. When I look at the mesh link and at radio profiles, I only see entries for 5 gHz and 2.4 gHz for this AP cluster.
    Do you know how to view the 60 gHz channel utilization and data?
  • 2.  RE: IAP387 Reviewing 60 gHz Radio
    Posted Jul 23, 2019 06:17 AM
    The IAP-387 does not have a 2.4GHz radio, it has 1x 5GHz and 1x 60GHz. Are you running on the latest firmware?
    Please check this post on how to set up the IAP-387 in standalone mesh mode which probably is what you want.
  • 3.  RE: IAP387 Reviewing 60 gHz Radio
    Posted Sep 04, 2019 02:52 PM
    Thanks for the info. I know the aps have only 60 gHz and 5 gHz radios on this model. However, the instant software only shows metrics for 2.4 and 5 gHz radios.
    The aps are currently set up in standalone mesh mode and linked through the 60 gHz radio, but I can't find what channel it is using or its uptime.
