IAP93 and 6.4.2.0-4.1.1.1 - 802.1x issue
  • 1.  IAP93 and 6.4.2.0-4.1.1.1 - 802.1x issue
    Posted Dec 18, 2014 10:00 AM
    Hia,
    we set up an 802.1x SSID with Internal Server for the authentication. WIth the ArubaOS  6.4.2.0-4.1.1.1 the SSID doesn't work; the clients aren't able to access the SSID. After trying in any way to figure out where the error was, simply downgrading the IAP93 to the ArubaOS 6.3.1.8-4.0.0.7 make the SSID works very well.
    So, is this an ArubaOS version bug? Is there someone else who has encountered the same problem?
    Massimo
  • 2.  RE: IAP93 and 6.4.2.0-4.1.1.1 - 802.1x issue
    Posted Dec 18, 2014 12:46 PM
    With an IAP-93 on 4.1.1.1 you cannot use the internet RADIUS server for 802.1x authentication.
    As per the release notes, the following features are not possible on the IAP-93.
    It is not a bug, features had to be removed from the older APs such as the 93s due to lack of memory footprint.
  • 3.  RE: IAP93 and 6.4.2.0-4.1.1.1 - 802.1x issue
    Posted Dec 19, 2014 03:01 AM
    Thanks Pasquale!
    I dont' see this on the release note..my mistake!
