IAP93 COnsole
  • 1.  IAP93 COnsole
    Posted Jun 08, 2012 03:24 AM
    Hi Forum,
    I want to purge  the IAP93 using console but i can't get its console.   I turned on  IAP93 using DC Adapter, take serial cable and connect its serial part of cable into PC serial port and then connect RJ45 cable into Console port of IAP93 and use Hyper terminal for console access but i can't get  any access there is nothing in hyper terminal window.   I want IAP 93 to purge rather than reset it.
    Solve my ISsue.
    Faisal
  • 2.  RE: IAP93 COnsole
    Posted Jun 08, 2012 10:37 AM
    You need to make sure the terminal is set:
    9600
    N
    1
    No Flow control
  • 3.  RE: IAP93 COnsole
    Posted Jun 08, 2012 12:58 PM
    Yes it is by default, but still cannot access
  • 4.  RE: IAP93 COnsole
    Posted Jun 08, 2012 07:03 PM
    Does it work with a controller or a different IAP93?
  • 5.  RE: IAP93 COnsole
    Posted Jun 09, 2012 02:01 AM
    It doesn't work with controller
  • 6.  RE: IAP93 COnsole
    Posted Jun 09, 2012 02:03 AM
    So I guess the problem is with your console cable or terminal configuration... :(
