IAP93 - Firmware upgradation
  • 1.  IAP93 - Firmware upgradation
    Posted Jun 18, 2021 02:23 AM
    Our IAP Cluster is IAP93
    The current FW version is 6.2.1.0-3.3.0.3_39227.
    To upgrade downloaded the latest FW ArubaInstant_Orion_6.4.4.8-4.2.4 from the ASP portal and upgraded to it.
    But the FW version not upgraded to the latest version and still showing the old version in the GUI.
    Any mistake I am doing?
    Thirunavukkarasu
    THIRUNAVUKKARASU P
  • 2.  RE: IAP93 - Firmware upgradation
    Posted Jun 18, 2021 07:39 PM
    I suggest read the release notes to see if you need to upgrade to a intermediate version or not.
    in either case try to upgrade to another version before the final version.
  • 3.  RE: IAP93 - Firmware upgradation
    Posted Jun 19, 2021 06:05 AM
    Thank you
    In the release notes there is no such thing for intermediate version. And I couldn't find any intermediate version in the Aruba ASP also
    Can you plz suggest me the intermediate version
    THIRUNAVUKKARASU P
  • 4.  RE: IAP93 - Firmware upgradation
    Posted Jun 21, 2021 01:35 AM
    Hi
    Thanks for the information.
    I'll try to upgrade as you advised.
    Unable to download the FW for ASP for the past few days
    THIRUNAVUKKARASU P
  • 5.  RE: IAP93 - Firmware upgradation
    Posted Jun 19, 2021 08:20 PM
    i suggest going with Orion_6.4.2.6-4.1.3.7_71499 and then upgrading to Orion_6.4.4.8-4.2.4.19_80086
  • 6.  RE: IAP93 - Firmware upgradation
    Posted Jul 02, 2021 07:29 AM
    Thank you.
    I'll try and update you
    THIRUNAVUKKARASU P
