last person joined: 4 hours ago
IAP93 Latest firmware code
  • 1.  IAP93 Latest firmware code
    Posted Sep 14, 2017 09:09 AM
    Other posts state that the 4.1.1.x code chain is the latest / last to support the IAP93 Specifically 6.4.2.6-4.1.1.11 although 6.4.2.6-4.1.1.13 is also available.
    Is this the latest supported code ?
    The support site does list 6.4.2.6-4.1.3.0 as supporting the IAP93 is this correct or an error?
    Will the whole 4.1.x.x code chain support the IAP93?
  • 2.  RE: IAP93 Latest firmware code
    Posted Sep 14, 2017 09:44 AM
    Yes.
  • 3.  RE: IAP93 Latest firmware code
    Posted Sep 15, 2017 03:08 AM
    Thanks Colin
