IAP+Airwave: incorrect transmit power
  • 1.  IAP+Airwave: incorrect transmit power
    Posted Nov 06, 2017 08:41 AM
    hi,
    i'm having issues with fixing transmit power for IAP-325.
    AW is latest 8.2.5, firmware is 6.5.4.3
    i've set manually to:
    yet, actual transmit power is different (though channels are correct and not changing):
    beforehand, IAP was managed as standalone and changing AP transmit power worked. Tried with older firmware, but the issue stays. i even set min TX power to 21 under ICG->system, but that haven't worked either
    i can sync all other configs, names, descriptions, even change channels.
    it's a single AP and i need a bit more "juice", as there's a client (sorf of ikiosk) that needs wifi access, but is pretty far away and sometimes loses connectivity
  • 2.  RE: IAP+Airwave: incorrect transmit power
    Posted Nov 06, 2017 08:52 AM
    What is the the regulatory domain of that IAP-325? Those access points might be limited based on channels/power depending on the regulatory domain.
  • 3.  RE: IAP+Airwave: incorrect transmit power
    Posted Nov 06, 2017 09:13 AM
    regulatory domain is configured as EE-Estonia (and country code too under Instant Gui)
    EDIT: i checked, there's no power supply restrictions (running from 802.11at injector)
    still shows that 2.4 Power (dB) is 18 (under show-techsupport), although it clearly got my configuration
    per-ap-settings 34:fc:b9:cf:be:e2 a-channel 36 22 g-channel 1 22 exit
  • 4.  RE: IAP+Airwave: incorrect transmit power
    Posted Nov 06, 2017 09:39 AM
    You should SSH into that IAP and run this commnd:
    show ap allowed-max-EIRP
    It will tell you the allowed maximum transmit power on each channel for that regulatory domain.
  • 5.  RE: IAP+Airwave: incorrect transmit power
    Posted Nov 06, 2017 09:48 AM
    you're right, max EIRP is 19 for 2,4G. thanks for clarification.
