iapo-103 slow wifi connection
  • 1.  iapo-103 slow wifi connection
    Posted Jan 02, 2017 02:21 PM
    I have 3 iap-103's. my laptop has a dual band 2x2 wifi card. If i make a connection on the 5Ghz it shows it is connected with 300mbps.
    When i do a speedtest it only reach arround 87mbps.
    How can i make the wifi faster? i think i should be able to get around 150mbps.
    I hope someone can help me.
    Danny
  • 2.  RE: iapo-103 slow wifi connection
    Posted Jan 02, 2017 02:56 PM
    If your laptop is the only device on that SSID, you are not broadcasting any other SSIDs, and there is no broadcast traffic on that subnet, you can possibly get to 150.  Otherwise, you would have to remove all clients from that SSID on that channel and enable "broadcast filter arp" on that SSID under advanced to possibly get to 150.
  • 3.  RE: iapo-103 slow wifi connection
    Posted Jan 03, 2017 07:26 AM
    This is allready configured. i just don't get over the 90mbps.
    Anything else i can configure?
    Danny
  • 4.  RE: iapo-103 slow wifi connection
    Posted Jan 03, 2017 07:38 AM
    What are you using for a speedway? How many SSIDs are you broadcasting?
  • 5.  RE: iapo-103 slow wifi connection
    Posted Jan 03, 2017 07:57 AM
    Hi What do you mean with speedway? The internet connection? that is a 300mb connection.
    I have 2 ssid's 1 for 2.4Ghz and 1 for 5Ghz.
    Danny
  • 6.  RE: iapo-103 slow wifi connection
    Posted Jan 03, 2017 08:10 AM
    with the same laptop at my office it is also connected to the wifi and here i get a download speed of 152mbps.
    So it is not the hardware in the laptop.
  • 7.  RE: iapo-103 slow wifi connection
    Posted Jan 03, 2017 09:28 AM
    What is the access point model that you have at your office?
  • 8.  RE: iapo-103 slow wifi connection
    Posted Jan 03, 2017 09:36 AM
    Thats a different brand. CIsco.
  • 9.  RE: iapo-103 slow wifi connection
    Posted Jan 03, 2017 12:44 PM
    What model? The AP-103 is not a top of the line AP.
  • 10.  RE: iapo-103 slow wifi connection
    Posted Jan 04, 2017 01:48 PM
    Ok so the iap 103 cannot go above 90mbps?
