IAPs no controller - External RADIUS set up
  • 1.  IAPs no controller - External RADIUS set up
    Posted Aug 03, 2012 03:23 PM
    I have 3 IAP's (no controller) set up with 2 SSID's.  One for guests and one for employees.  Both work fine.  Employee is currenlty set to WPA2.  So I am able to connect and browse my LAN.
    I have set up a test SSID and want use authentication to provide security.  I have server 2008 R2 set up with NPS.   (Currenlty using it for dial in permissions for VPN users)
    Dynamic RADIUS proxy is enabled
    RADIUS server up under PEF settings.  Verified shared key is correct.
    What needs to be done on the RADIUS server?  I have added the RADIUS client (my Virtual Controller IP)
    What connection request policy or network policy is required to authenticate my users?
  • 2.  RE: IAPs no controller - External RADIUS set up
