Cloud Managed Networks
IAPs setting up and joing different Virtual Controllers
  • 1.  IAPs setting up and joing different Virtual Controllers
    Posted Jul 06, 2018 07:03 AM
    Hi all,
    First time setting up IAPs and using Aruba Central; some of my APs have joined a single Virtual Controller and others have created and joined their own VC - I've looked and searched and can't find anything conclusive on how to make all the APs join a single VC and I can't delete the others...Any offers?
    Thank you,
    Dan
  • 2.  RE: IAPs setting up and joing different Virtual Controllers
    Posted Aug 07, 2018 04:08 AM
    If your APs are in the same broadcast domain they should automatically form a cluster. Can you provide more info about what's going on?
  • 3.  RE: IAPs setting up and joing different Virtual Controllers
    MVP EXPERT
    Posted Aug 07, 2018 04:20 AM
    I've had this happen before and it is usually a switch port issue (VLANs incorrect or native is wrong...), so check these first. Do you have auto-join enabled on the VC as well?
