IAPs suddenly rebooted and each became a separate VCs
  • 1.  IAPs suddenly rebooted and each became a separate VCs
    Posted Feb 07, 2014 10:19 PM
    One of our clients has four Aruba 225 and two Aruba 93 IAPs. I was adding a new Aruba 225 to the IAP cluster and after connecting it all the IAPS suddenly rebooted. After this event when I accesed the VC IP address, I was able to see only one AP in the VC cluster. On further examination I realized that all Aruba 225 had became "independent" virtual controllers. Each of them trying to respond to the VC IP address, and controlling only one AP. I had to do reboot a couple of times most of the APs for them to become a cluster again.
    - What could have caused this problem?
    - Are there any commands to debug the master election process?
    - Is there a way to prevent the cluster from "separating" from itself?
    About our client's topology:
    - All APs were running OS 6.3.1.1-4.0.0.1
    - The AP management lan is the untagged VLAN on the cable.
    - The two SSIDs, use a tagged VLAN each.
    - The new AP had the same OS as the cluster.
    #AP225
  • 2.  RE: IAPs suddenly rebooted and each became a separate VCs
    Posted Feb 07, 2014 10:41 PM
    Hello Rodrigo
    Thats definitly not normal...
    I would open a support case with ArubaNetwork TAC, this looks like a bug... and it needs to be addresed!
    Cheers
    Carlos
  • 3.  RE: IAPs suddenly rebooted and each became a separate VCs
    Posted Feb 07, 2014 10:49 PM
    What version was running on the AP225/AP93 cluster?
  • 4.  RE: IAPs suddenly rebooted and each became a separate VCs
    Posted Feb 07, 2014 10:51 PM
    Hello Yan
    HE mentioned the version running on the original post.
    Cheers
    Carlos
  • 5.  RE: IAPs suddenly rebooted and each became a separate VCs
    Posted Feb 08, 2014 08:15 AM
    I have seen similar where there were dhcp issues and then the APs couldn't get an ip and seemingly reset themselves.
    When they came back online I found that they were all back to factory default and I had to reconfigure again.
  • 6.  RE: IAPs suddenly rebooted and each became a separate VCs
    Posted Feb 12, 2014 05:05 AM
    Hello Rodrigo,
    Could it be a problem on the wired network? If the IAPs for some reason don't see each other, then they think to be alone and so they become VC.
    Massimo
  • 7.  RE: IAPs suddenly rebooted and each became a separate VCs
    Posted Feb 12, 2014 04:28 PM
    Thanks for your replies.
    I checked with the switch staff on that company and there was a configuration change that rendered the network stable during the period we experienced the downtime. After the unstability was resolved and a couple of reboots our 225 joined and became a Virtual Controller. Our APs 93 did not join so I contacted Support. It appears that there is an issue that affected 4.0.0.1, that we can solve by updating to 4.0.0.3.
