IAPs with different AD Groups
  • 1.  IAPs with different AD Groups
    Posted Jul 15, 2013 08:57 AM
    Hi community,
    I´ve a problem, we´ve 14 IAPs with 3 SSIDs.
    I want to authenticate all 3 SSIDs with the same DC. (Windows 2008 R2)
    I´ve created different (3) Groups in AD.
    I want that the group 1 can only authenticate on the ssid 1, not ssid2 or ssid3.
    group 2 only authenticate on ssid 2 not on ssid 1 and ssid3 and so on.
    How can I make this?
    Is it possible?
  • 2.  RE: IAPs with different AD Groups
    Posted Jul 15, 2013 03:15 PM
    yes with configuration of Aruba VSA and use "Aruba-ESSID" option, we can create nps policy to accomidate this.
  • 3.  RE: IAPs with different AD Groups
    Posted Jul 16, 2013 03:12 AM
    Ok, this woks with IAPs?
    How can I configure this? Do you haven a step by step manual or something?
    Maybe you can shortly discribe the steps to configure this?
  • 4.  RE: IAPs with different AD Groups
    Posted Jul 16, 2013 08:03 AM
    Change in thought. the following will be much easier.
    Create a separate server group  and radius server config for each eSSID and the set the NAS-ID in the server group to match the eSSID. That way, you can use a standard RADIUS attribute (NAS-ID) in your IAS rules to enforce per-SSID policies. Works perfectly. The only down side would be creating multiple AAA profiles.
