IAS without CA
  • 1.  IAS without CA
    Posted Jul 17, 2012 05:38 AM
    Hi Forum,
    I want to use IAS and AD for authentication without using anycertificate or CA, is it possible please share help or configuration with me.
    I read different articles but they all include CA for authentication.
    Faisal
  • 2.  RE: IAS without CA
    Posted Jul 17, 2012 11:36 AM
    If you want to to 802.1x authentication (whether with client certificates or just username/password), you'll still need a certificate on the RADIUS/IAS side.    This can be a cert purchased from a public trusted authority, one issued from an internal PKI (for example a Microsoft PKI),   or a self-signed certificate.   Either way, you'll want to either make sure your clients trust the certificate (can be pushed through AD if you use a self-signed certificate) or tell the clients not to validate the server certificate (typically not recommended).
    I usually use makecert.exe to do self-signed certificates.  You just need to ensure it has the Server Authentication purpose.  A sample is:
    makecert.exe -n "CN=dc.mydomain.local" -sr LocalMachine -ss my -r -pe -eku 1.3.6.1.5.5.7.3.1 -sky exchange -sp "Microsoft RSA SChannel Cryptographic Provider" -sy 12 -e 01/01/2025
    This will create the certificate and iinstall it to the Local Machine's certificate store; you can then reference it in your IAS policies.
    Other options for makecert:
    http://msdn.microsoft.com/en-us/library/bfsktky3(v=vs.71).aspx
