identify concurrent session
  • 1.  identify concurrent session
    Posted Mar 16, 2015 11:40 PM
    I want to identify concurrent session of emplyee. I must use clearpass right ?? but i want to know that Can I use this feature on clearpass ( onboard module ) ??
  • 2.  RE: identify concurrent session
    Posted Mar 17, 2015 03:35 AM
    Start
    When you say "identify current session", what kind of data do you want to identify?
  • 3.  RE: identify concurrent session
    Posted Mar 17, 2015 03:48 AM
    for example
    Mr. A there's user "emp01"
    then Mr.A can login by using "emp01" username only 1 device
  • 4.  RE: identify concurrent session
    Posted Mar 17, 2015 04:06 AM
    If it is a captive portal on the controller, can use the "allow only one active user session" paramter in the Captive Portal Authentication Profile on the controller (http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Captive_Portal/Captive_Portal_Authentic.htm) to limt the user to a single session.
    If this is 802.1x authentication, you need a radius server like ClearPass Policy manager that leverages radius accounting to limit the number of sessions.
  • 5.  RE: identify concurrent session
    Posted Mar 17, 2015 04:08 AM
    It's 802.1X authentication. Do you have any configuration guide
  • 6.  RE: identify concurrent session
  • 7.  RE: identify concurrent session
