IDS Signature match and containment
  • 1.  IDS Signature match and containment
    Posted Mar 07, 2013 01:57 AM
    We are using OS 6.1 and we need to auto-contain systems that emits signatures that matches our IDS signatures. I looked at the documentation for containment of signals/ signatures that matches a specific IDS signature but it does not say how and where is this configured. Please provide some guidance if you know. Thanks.
  • 2.  RE: IDS Signature match and containment
    Posted Mar 07, 2013 05:51 AM
    You can only detect signatures and report them.
  • 3.  RE: IDS Signature match and containment
    Posted Mar 07, 2013 09:37 AM
    This is a surprise to me. Thanks.
  • 4.  RE: IDS Signature match and containment
    Posted May 28, 2014 10:49 PM
    So we can´t contain a deauth attack?
    Regards.
  • 5.  RE: IDS Signature match and containment
    Posted May 31, 2014 08:36 AM
    look at the last reply, you can do something if you use 6.4 and the client support 802.11w:
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Block-deauth-attack-with-Aruba-WIPS/td-p/165634
    but in general deauth attack is a tricky attack to mitigate, you cant prevent a client from sending things into the air.
  • 6.  RE: IDS Signature match and containment
    Posted Jun 02, 2014 10:43 AM
    Ok, thanks.
