If Have More than 1 controller what is the right way to write Option 43 Command ?
  • 1.  If Have More than 1 controller what is the right way to write Option 43 Command ?
    Posted May 17, 2014 06:58 AM
    What is the best wayto right Option 43 Command if I have more than 1 controller for example Master IP:192.168.1.100 and stand by Master IP :192.168.1.101 and 2 local controller ,local 1 IP:192.168.1.102,Local 2 IP:192.168.1.104 How I can Type Option 43 command for all of this Controllers,Kindly I Need to understand this process.
  • 2.  RE: If Have More than 1 controller what is the right way to write Option 43 Command ?
    Posted May 17, 2014 08:33 AM
    You would use the VRRP IP adress of the master and standby controller. when failover occurs the APs would still be directed to their local controller via the standby controller.
  • 3.  RE: If Have More than 1 controller what is the right way to write Option 43 Command ?
    Posted May 17, 2014 08:35 AM
    Option 43 should point to the VRRP address of your master controllers. The
    APs will use the LMS-IP to contact the appropriate local controller.
