if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
  • 1.  if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
    Posted Jul 14, 2015 08:27 AM
  • 2.  RE: if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
    Posted Jul 14, 2015 08:30 AM
    It's an automatic process. If af power is used, the AP will go into a "lite" mode and drop the 2.4 radio to a single stream and disable the USB port. You don't need to manually do anything.
    <EDITED, MISREAD>  This only applies to the 220 series.
  • 3.  RE: if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
    Posted Jul 14, 2015 10:25 AM
    thanks for the quick reply, we were going to create a radio profile with  2.4  radio manually turned off  anyway for a different reason , other than PoE .....  very high density user area , saturated with 2.4 channels already  and did not want to rely on ARM , band steering and spectrum load balancing to avoid the problems caused by channel interference .
    We are completely BYOD environment and so cannot test behaviour of all clients with band steering  spectrum load balancing etc.
  • 4.  RE: if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
    Posted Jul 14, 2015 08:54 AM
    The AP-215 can fully operate off of 802.3af power.   The 225 will automatically disable the chain and USB port as Tim suggests.
  • 5.  RE: if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
    Posted Jul 14, 2015 10:41 AM
    thanks for the reply. Forgive me if this is a silly question :  If the AP215   does not support automatically adjusting the number of radio chains, then how does the AP215 manage on  802.3af ?
  • 6.  RE: if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
    Posted Jul 14, 2015 10:54 AM
    The AP-215 can run with a full feature set on af power.
  • 7.  RE: if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
    Posted Jul 14, 2015 11:01 AM
    thankyou .last question , promise . Found this on the spec sheet for aP215 :
    --"USB port is disabled when using an 802.3af PoE power
    source; for unrestricted operation with PoE power, use
    an 802.3at compliant source"
    In what scenario would you use a usb port on the AP215 - just curious ?
  • 8.  RE: if I manually turn off the 2.4 3x3x3 radio chain manually in an AP215, will 802.3af poe suffice ?
    Posted Jul 14, 2015 11:03 AM
    Aruba Beacons and 4G LTE connectivity.
