If Ihave 2 controllers each one is stand alone can I authentiate users from another controller?
  • 1.  If Ihave 2 controllers each one is stand alone can I authentiate users from another controller?
    Posted Oct 28, 2014 05:28 PM
    If I have 2 Controllers Each one is standalone role Master can I authenticate guests from controller to another?
  • 2.  RE: If Ihave 2 controllers each one is stand alone can I authentiate users from another controller?
    Posted Oct 28, 2014 05:52 PM
    No, they would authenticate to RADIUS separately (I assume you mean RADIUS/dot1x authentication).
  • 3.  RE: If Ihave 2 controllers each one is stand alone can I authentiate users from another controller?
    Posted Oct 28, 2014 07:53 PM
    Are you referring to using the built-in controller captive portal?
    You could create a GRE tunnel between the controllers and have one of them server as the guest portal. Otherwise you would need a RADIUS server.
