IF-MAP Down - SSL certificate problem: self signed certificate
  • 1.  IF-MAP Down - SSL certificate problem: self signed certificate
    Posted Apr 07, 2020 04:53 PM
    I am trying to establish an IF-MAP connection between a 7010 controller and a ClearPass using self signed certificates.
    The IF-MAP stays down and the message we can see at the controller is the one below:
    192.168.254.9:443 DOWN [04/07/20 15:04:20] SSL certificate problem: self signed certificate
    7010 is running OS 8.6.0.3 as a device managed by a Mobility Master VA
    ClearPass is the CLAVB 6.9.0.130064
    What would be the solution using the self signed certificate issued by the ClearPass?
    Thank you
  • 2.  RE: IF-MAP Down - SSL certificate problem: self signed certificate
    Posted Apr 08, 2020 08:27 AM
    It is not recommended to run ClearPass with self-signed certificates, so the recommendation is to get a proper certificate and install that. If you don't need external client trust, you could use an internal/private CA to generate the ClearPass HTTPS certificate. If you don't have a private CA, you may leverage the Onboard CA for that.
    You may try if it works to import the ClearPass self-signed certificate in the controller as Trusted CA, but haven't tried that.
  • 3.  RE: IF-MAP Down - SSL certificate problem: self signed certificate
    Posted Apr 08, 2020 08:32 AM
    This is the point where I am facing the problem. When I try to import the Clearpass certificate as a trusted CA, the error below pops-up:
    Certificate does not have the basicConstraints extension CA flag set.
    I can only import it as a server certificate.
