If upgrade OS "Always upgrade the non-boot partition first" , Could anyone explain it in more detail
  • 1.  If upgrade OS "Always upgrade the non-boot partition first" , Could anyone explain it in more detail
    Posted Apr 03, 2016 09:01 AM
    We are planning to upgrade controller OS, according to realease notes, for upgrade procedure, "Always upgrade the non-boot partition first", could anyone please advise how to do it? Thanks in advance.
  • 2.  RE: If upgrade OS "Always upgrade the non-boot partition first" , Could anyone explain it in more detail
    Posted Apr 03, 2016 09:07 AM
    When you try to upgrade the controller using the GUI, two partitions are shown.  One partition will say [**default boot**] next to the description.  That is the default boot partion.  You should upgrade the opposite partition.
    The document says to upgrade the non-boot partition so that you can easily switch back to the partition you were running without uploading an image if there were any issues.  Many people are confident in the image they are upgrading to and ignore this.  It is mainly a time-saver if you have to revert.
  • 3.  RE: If upgrade OS "Always upgrade the non-boot partition first" , Could anyone explain it in more detail
    Posted Apr 03, 2016 09:20 AM
    Thanks a lot
