IfInOctets=0, IfOutOctets=0 for Aruba IAP Version 6.4.2.0-4.1.1.1
  • 1.  IfInOctets=0, IfOutOctets=0 for Aruba IAP Version 6.4.2.0-4.1.1.1
    Posted Feb 19, 2015 08:04 AM
    Hi Aruba Community,
    We would be glad if you help us solving a problem that we are facing for an Aruba IAP Version 6.4.2.0-4.1.1.1
    The IF-MIB values that are returned for this IAP for ifInOctects and ifOutOctets are zero. This results into empty traffic graphs in our monitoring solution.
    Sample snmpbulkwalk output is here.
    Caching Oids: ifEntry
    CMD[^[[0;33m/usr/bin/snmpbulkwalk -v3 -l 'authPriv' -n "" -x *** -X *** -a *** -A *** -u *** -OQUs -m IF-MIB -M /opt/observium/mibs/rfc:/opt/observium/mibs/net-snmp 'udp':'device_hostname':'161' ifEntry^[[0m]^[[0m
    STDOUT[
    ifIndex.1 = 1
    ifIndex.2 = 2
    ifIndex.54 = 54
    ifIndex.70 = 70
    ifIndex.90 = 90
    ifIndex.500 = 500
    ifDescr.1 = eth0
    ifDescr.2 = eth1
    ifDescr.54 = radio0_ssid_id4
    ifDescr.70 = radio1_ssid_id0
    ifDescr.90 = gre0
    ifDescr.500 = BR0
    ifType.1 = gigabitEthernet
    ifType.2 = fastEther
    ifType.54 = radioMAC
    ifType.70 = radioMAC
    ifType.90 = tunnel
    ifType.500 = other
    ifInOctets.1 = 0
    ifInOctets.2 = 0
    ifInOctets.54 = 0
    ifInOctets.70 = 0
    ifInOctets.90 = 0
    ifInOctets.500 = 0
    ifOutOctets.1 = 0
    ifOutOctets.2 = 0
    ifOutOctets.54 = 0
    ifOutOctets.70 = 0
    ifOutOctets.90 = 0
    ifOutOctets.500 = 0
    ifHCInOctets.1 = 0
    ifHCInOctets.2 = 0
    ifHCInOctets.54 = 0
    ifHCInOctets.70 = 0
    ifHCInOctets.90 = 0
    ifHCInOctets.500 = 0
    ifHCOutOctets.1 = 0
    ifHCOutOctets.2 = 0
    ifHCOutOctets.54 = 0
    ifHCOutOctets.70 = 0
    ifHCOutOctets.90 = 0
    ifHCOutOctets.500 = 0
    Has anyone seen this before, what is the possible cause and solution to this.
    Thank-you,
    Manjiri
  • 2.  RE: IfInOctets=0, IfOutOctets=0 for Aruba IAP Version 6.4.2.0-4.1.1.1
    Posted Feb 27, 2015 12:24 AM
    Can someone please reply to this query. Its urgent.
  • 3.  RE: IfInOctets=0, IfOutOctets=0 for Aruba IAP Version 6.4.2.0-4.1.1.1
    Posted Mar 03, 2015 03:26 PM
    for urgent queries there is Aruba support to contact.
  • 4.  RE: IfInOctets=0, IfOutOctets=0 for Aruba IAP Version 6.4.2.0-4.1.1.1
    Posted Mar 11, 2015 04:08 AM
    I'm having the same issue - using Observium for monitoring. I'm not seeing the client count on my IAP's either.
    did you find a solution for this?
  • 5.  RE: IfInOctets=0, IfOutOctets=0 for Aruba IAP Version 6.4.2.0-4.1.1.1
    Posted Mar 11, 2015 04:30 AM
    Aruba has Mibs on its website that can be downloaded to provide support.  With regards to Observium, specifically, there is no guarantee with Observium that developers would provide support for Aruba Instant http://postman.memetic.org/pipermail/observium/2014-June/006981.html
    Maybe others can chime in if they have gotten this figured out with Observium.
  • 6.  RE: IfInOctets=0, IfOutOctets=0 for Aruba IAP Version 6.4.2.0-4.1.1.1
    Posted Mar 11, 2015 05:01 AM
    Thanks for the quick response Colin.
    I understand there is no guarantee, I was hoping to find the oid for number of associated clients (per ap or per radio) - I've checked the MIB reference guide 6.4.0.2 I don't see an oid for total clients - does this exist?
    thanks
  • 7.  RE: IfInOctets=0, IfOutOctets=0 for Aruba IAP Version 6.4.2.0-4.1.1.1
    Posted Mar 11, 2015 02:46 PM
    You would have to total the number of objects in the user table. There is no MiB that has the total count.
