I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
  • 1.  I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Nov 25, 2015 07:27 PM
    I'm setting up an IAP200 as a trial, as a single AP (not connected to an AP network). The instructions say to connect to the "instant" SSID, which I did, then to go to http://instant.arubanetworks.com to configure, but I can't get to it. Looking for suggestions!  : )
  • 2.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Nov 25, 2015 07:29 PM
    Are you supplying the instant AP with DHCP?
    Do you get an ip address on your client that can resolve a DNS address?
  • 3.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Nov 25, 2015 07:36 PM
    I had an IP, which was in the same range as the DNS source (173...). I guess I assumed that I was getting DHCP from the AP. Bad assumption?
  • 4.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Nov 25, 2015 07:37 PM
    I should say that this AP is plugged directly into my cable modem. I believe that my old AP was supplying my DHCP, not the modem.
  • 5.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Nov 25, 2015 07:38 PM
    Is your client on the same subnet as the AP, or does it get a private address?
  • 6.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Nov 26, 2015 12:25 AM
    The IP of the client and the AP (listed as gateway) were in the same subnet.
  • 7.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Nov 26, 2015 01:06 AM
    Here is more information:
    Client IP: 172.31.98.183
    Subnet Mask: 255.255.254.0
    Router: 172.31.98.1
    DNS: 208.67.222.123
    Could not ping the router, could not ping instant.arubanetworks.com
    Did a lookup of instant.arubanetworks.com which returned 169.254.60.90 - could not ping this.
    (FYI: client is a Mac) Hope this is helpful!
  • 8.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Dec 03, 2015 06:50 AM
    Hi, can I get some more ideas? I appreciate any help!
    Router: 172.31.98.1
    DNS: 208.67.222.123
    Router: 172.31.98.1
    DNS: 208.67.222.123
  • 9.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Dec 03, 2015 06:52 AM
    Do you see the instant SSID?  Can yo figure out what ip address the instant AP got and browse to that address?
  • 10.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Dec 09, 2015 11:52 PM
    I could not ping the router, could not ping instant.arubanetworks.com
    Did a lookup of instant.arubanetworks.com which returned 169.254.60.90 - could not ping or get to this.
  • 11.  RE: I'm setting up an IAP200 - can't get to the Instant UI - when connected to instant ssid
    Posted Dec 27, 2015 01:27 PM
    not sure if you are still working on this, but it seems your AP isn't getting a IP via DHCP, so check that first.
    if you have a console cable you can check that way.
