I'm trying to add an IAP to Airwave, but is not connecting
  • 1.  I'm trying to add an IAP to Airwave, but is not connecting
    Posted Jul 16, 2015 09:29 AM
    I configured my IAP with the Airwave IP and Organization name and passphrase but when cheking my Airwave I don't see any new APs. I test reachability between networks and it is ok. Do I have to configure something in the Airwave?
  • 2.  RE: I'm trying to add an IAP to Airwave, but is not connecting
    Posted Jul 16, 2015 10:11 AM
    What type of IAP ?
    Version of OS on the IAP ?
    Version of Airwave ?
    Are you allowing port 443 between the IAP and Airwave ?
  • 3.  RE: I'm trying to add an IAP to Airwave, but is not connecting
    Posted Jul 16, 2015 10:29 AM
    Hi this is the device I have:
    W-AP115
    6.3.1.1-4.0.0.1_41049
    AIRWAVE 8.0
  • 4.  RE: I'm trying to add an IAP to Airwave, but is not connecting
    Posted Jul 16, 2015 01:32 PM
    did you load a backup from another IAP into this IAP-115?
    If so, change a value in the virtual-controller-key.
    for example
    FROM: virtual-controller-key 21424572abc3237342def23523de
    TO: virtual-controller-key 21424572abc3237342def23523f
  • 5.  RE: I'm trying to add an IAP to Airwave, but is not connecting
    Posted Jul 16, 2015 08:41 PM
    I have another IAP the same version and is working fine. This IAP is a new one. I'm not seen connection attemps to AW from this AP. Please check the attached file.
    Rgds,
    EH
    Attachment(s)
    docx
    Review VC.docx   566 KB 1 version
  • 6.  RE: I'm trying to add an IAP to Airwave, but is not connecting
    Posted Jul 19, 2015 02:51 PM
    you seem to have one IAP in airwave which you first have to approve.
    then the second, is it in the same cluster or different?
