I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
  • 1.  I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 04:32 PM
    I try first to use this procedure to test only L2 MAC Address Authentication but is not working:
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/For-the-Beginner-MAC-Authentication-using-the-Controller/ta-p/32188
    I can notice that controller version shown in the link is different from mine:
    mine: 6.4.2.4
    my WLC is a 7030
  • 2.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 04:34 PM
    Are you using PSK or 802.1X authentication?
    Tim
  • 3.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 05:05 PM
    Hi, I'm going to use PSK WAP2-AES.
  • 4.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 05:07 PM
    Can you post a screenshot of your AAA profile?
    Tim
  • 5.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 05:11 PM
    I deleted all configuration of MAC but was the same as the Link I sent.
    I created a MAC Auth profile in Security > Authentication > L2 Authentication with colon and lower, then the server group,... and so on just as the link said. Tried twice!
  • 6.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 05:13 PM
    If the user fails MAC auth, they will be dumped into the initial role. Is that the role the device got?
    Tim
  • 7.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 05:37 PM
    user in bold letter is the only user added to the internal database:
    local-userdb add username 84:3a:4b:29:19:52 password 84:3a:4b:29:19:52
    WLC_WIFI) #show user-table
    Users
        IP              MAC            Name              Role           Age(d:h:m)  Auth  VPN link  AP name  Roaming   Essid/Bssid/Phy               Profile         Forward mode  Type   Host Name
    192.168.1.105  84:3a:4b:29:19:52  84:3a:4b:29:19:52  guest          00:00:59    MAC             Stock-2  Wireless  TEMPO/94:b4:0f:91:7a:f3/a-HT  TEMPO-aaa_prof  tunnel        Win 7
    192.168.0.24   6c:88:14:45:fb:cc                     authenticated  00:00:59                    Stock-2  Wireless  TEMPO/94:b4:0f:91:7a:f3/a-HT  TEMPO-aaa_prof  tunnel        Win 7
    User Entries: 2/2
     Curr/**bleep** Alloc:8/937 Free:5/929 Dyn:13 AllocErr:0 FreeErr:0
  • 8.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 06:40 PM
    What is your initial-role set to?
    What is the role you assigned to that MAC in the internal database?
  • 9.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 10:17 PM
    Hi, I think that your question was the key to solve the problem I had. I put the initial role in deny all. Then when I used any machine defined in Internal database, everything works fine. Can I define users by groups, to use some MACs for an SSID and the some other MACs for other different SSID. How can I do this?. Creating a new role?
  • 10.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 10:34 PM
    No, you would need an external policy engine like ClearPass to get that
    granular.
  • 11.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 18, 2015 10:36 PM
    Thanks a lot for your help!!!
  • 12.  RE: I'm trying to enforce L2 security using MAC Address in conjunction with WPA2-AES, but not working
    Posted Feb 19, 2015 01:02 PM
    Yeah you can do this but if you have a small number of users, and if you have a large number of users as Tim said, You have to go for CPPM.
    For doing that first you have to create one user role  and then add the users MAC ids on that, after that in AAA profile just select the user derived role from the drop down list. So it will overwrite your default role and make them work.
