Image_check_internal error 001 code 02
This thread has been viewed 27 times
  • 1.  Image_check_internal error 001 code 02
    Posted Aug 03, 2019 10:22 PM
    So I searched this and I dont see a solution. I have this error on every IAP in all clients.. It is supposed to be a backend system issue, but, its on 3 months now..
    Whats the current update on this.
  • 2.  RE: Image_check_internal error 001 code 02
    Posted Aug 03, 2019 10:29 PM
    The update is that it is not fixed, and there is no ETA.  For now, please update manually.
  • 3.  RE: Image_check_internal error 001 code 02
    Posted Jun 16, 2022 09:03 AM
    it is now June of 2022 and I am still getting this error when checking for updates for my IAP-305s.  will it ever get fixed.  updating manually is a workaround but it seems that it is the only way forward with this device class.
  • 4.  RE: Image_check_internal error 001 code 02
    Posted Jun 18, 2022 07:04 PM
    in the mea time have this link handy and use the 'limited lifetime warranty' to download image for the AP model.
    You can download the lifetime warranty firmware without a login.
    In order to do that, search for 'factory image' on ASP: https://asp.arubanetworks.com/downloads;search=factory;products=Aruba%20Access%20Points
