Image size to large when connecting AP to controller
This thread has been viewed 59 times
  • 1.  Image size to large when connecting AP to controller
    Posted Sep 18, 2020 01:47 PM
    Hey!
    Is there any way i can get my AP (325) to join my controller? It tries to update itself but complains about too large image, then cancels and reboots. This keeps going over and over
    Licenses and everything is in check. Anyone know what to do?
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  lms 192.168.1.222 file ipq806x.ari part 1 strap 0 preload 0 size 12691408
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  vm.min_free_kbytes = 10
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  mem free 387452 minimum 18589 (memmin 12693)
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  /aruba/bin
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Running /aruba/bin/ncftpget  -V -g 1 -u *** -p *** -t 5,5,5  -B 8192 192.168.1.222 . ipq806x.ari
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Remote read timed out.
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Finished downloading 8872420 bytes
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Transferred bytes 8872420 don't match hdr info 12691408
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  ncftpget ipq806x.ari: bad checksum.
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  FTP Failed: 3. Trying FTP again
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Finished downloading 12691408 bytes
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  c.ncftpget ipq806x.ari: image too large.
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  FTP Failed: 3. Trying TFTP.
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Running /aruba/bin/sap-tftp -g -r ipq806x.ari -l ipq806x.ari -P 1 192.168.1.222
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Image size 12691408 is > 12582912, not upgrading. Exiting
    Sep 18 21:12:09,  sapd[2151]: <311014> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Flash Image upgrade failed: Result code 255
    Sep 18 21:12:10,  sapd[2151]: <311002> <WARN> |AP b4:5d:50:c6:5d:ec@192.168.1.88 sapd|  Rebooting: SAPD: Reboot after image upgrade failed: 65280
    Sep 18 21:12:11,  nanny[2098]: <303086> <ERRS> |AP b4:5d:50:c6:5d:ec@192.168.1.88 nanny| Process Manager (nanny) shutting down - AP will reboot!
  • 2.  RE: Image size to large when connecting AP to controller
    Posted Sep 18, 2020 02:26 PM
    What version of ArubaOS are you trying to upgrade to?  Do you have a console cable?
  • 3.  RE: Image size to large when connecting AP to controller
    Posted Sep 18, 2020 02:42 PM
    Im trying to upgrade to 8.6
    I think the AP has 6.3 or something on it. And no unfortunately I don't have a console cable here. Could I fix with that?
    Thanks for the answer!
  • 4.  RE: Image size to large when connecting AP to controller
    Posted Sep 18, 2020 03:27 PM
    If you get a console cable, we might be able to fix it with that...
  • 5.  RE: Image size to large when connecting AP to controller
    Posted Sep 20, 2020 01:32 PM
    Thanks all! I got hold of a console cable and fixed it today As simply as setting my tftp address and flash it. Lol. But how come this wasnt doable from the controller?
  • 6.  RE: Image size to large when connecting AP to controller
    Posted Sep 21, 2020 04:18 AM
    This has been seen on a few APs that mostly are on an old factory image (6.4.4 was mentioned once). First upgrading to a recent 6.5 would probably have helped as well to upgrade to 8.x after that without console access. With a few APs and console access, the flash from apboot probably is easier. It has more to do with the old firmware version, and 6.4 is pretty old, so you make a big jump going to 8.x.
    Glad you solved it.
  • 7.  RE: Image size to large when connecting AP to controller
    MVP
    Posted Aug 30, 2022 01:21 PM
    EDIT: I think I figured it out. I had to clear both os paritions (0 and 1) to make enough space. AP is now up on my cluster with latest image.
    Think I'm having a similar issue. Had to factory reset an AP-325 (which has 6.4.4.0 by default). Current production is at 8.10.0.2.
    I keep getting errors like:
    ERROR: File size exceeded 14680064 bytes
    Via console access Ive tried factory_reset and purgeenv - no luck. Then factory_reset and purgeenv and tftpboot - no luck.
    Is there a different order of commands to try? Or am I at the point of RMAing this AP?
  • 8.  RE: Image size to large when connecting AP to controller
    Posted Aug 31, 2022 12:23 PM
    I have had to open a case about this as well. We've had to move up in code to accommodate the newer AP models like some of the 500 series, but also still have AP 105s that need to be upgraded before certain clusters can move up in code. I found out about this issue after trying to repurpose bunch of our 325 APs from 8.7 to 8.6 so these APs were working. However, our procedure is to factory reset the AP before sending it back out into the field which of course puts some of them back to code 6.4.4.0. If I recall the lowest magical code that will work on the 8.7 version that we are running is 6.4.4.8 or something very close to that.
    There was a version of code that was released where you could run a command on the MM or MD not sure at the moment that supposedly put whatever version of code running on the MM on the APs backup partition (can be found in the release notes of 8.7.1.9). In our case we have found this command does not work hence the case I've opened. We currently have about 500+ AP325 that will fall into this category and would really like to upgrade them before taking them offline and factory resetting them.
    The solution we have been using is to manually install the code on the AP once it has been factory reset. I've found that this version of code works the best for all our APs that need their OS upgraded - ArubaInstant_Hercules_8.3.0.15_79362. I've added this version of code to the flash on one of the controllers so that while the AP is booting I can break the boot cycle to push the code to it using - upgrade os 1 (ip of controller):
    Basically, this is what we are dealing with, but I really want to ask everyone here is has anyone been able to get this command to work for them? Here is the information that was released in 8.7.1.9
    Starting from ArubaOS 8.7.1.9, the following CLI commands have been enhanced:
    apflash command
    The ap31x-ap32x backup partition parameter has been added to the apflash command to upgrade the backup
    partition of Aruba 310 Series and 320 Series access points running ArubaOS 6.4.x or earlier versions to the
    ArubaOS version running on the Mobility Master.
    (host) [mynode] #apflash ap31x-ap32x backup partition
    A
  • 9.  RE: Image size to large when connecting AP to controller
    Posted Sep 01, 2022 04:02 AM
    There is a field bulletin available for partners and customers, which you can request from your local Aruba SE, or Aruba support. Early models of the AP-32x are loaded with a 6.4.4 backup image which does not fully support current sizes of firmware. Solution is the provided command, which is available in
    ArubaOS 6.5.4.23, ArubaOS 8.6.0.17, ArubaOS 8.7.1.9, ArubaOS 8.9.0.3, ArubaOS 8.10.0.0 and later. By first upgrading to one of these versions (or newer), then flash the backup image, you can then upgrade to AOS 8.10+ or AOS 10.x.
    Manual flashing from apboot (as censania did) of course works as well, but in larger networks using that apflash command is more convenient.
    With the 'show ap image version' command you can check the backup partition version for APs that are currently connected.
  • 10.  RE: Image size to large when connecting AP to controller
    Posted Sep 07, 2022 04:10 AM
    in order to use the command you will have to get the APs to the connect to your controller. they have to be operating properly before you can use the command.
    once you issue the command, it will upgrade batches of 5 APs, and then continue. you will only get feedback via show log or show ap database.
    It takes a while for the command to do its magic.
    After about 100 or so, you may need to re-issue the command.
    It works, it's silent ... do not lose patience.
    getting the APs to the required controller version may be a problem.
    If an AP is in factory default it will run from the backup partition, and if that backup image is 6.4.4.0 (I believe) you may run into the problem.
    Either do an interim upgrade to a lower software version, e.g. 8.5.x on a spare controller, and then go to e.g. 8.7.1.9  or use the serial cable as mentioned above.
