image verify failed - Conversion of IAP 115's to CAP
  • 1.  image verify failed - Conversion of IAP 115's to CAP
    Posted May 24, 2014 11:32 PM
    I'm getting this message when trying to run a conversion of 10 IAP 115's.  While researching this I'm finding older threads that mention the controller needing to run 6.1.  All of the equipment was just received from distribution and the Controller is running 6.1.3.6 and the IAP 115's are running 6.3.1.1  Does the same idea still apply, meaning the Controller should be on at least what the APs are on?  Looking at AOS GA, if tihs is correct, then I'll need to install 6.3.1.7.  Just wanted some reassurance before I do it.
    Thanks for any help!
  • 2.  RE: image verify failed - Conversion of IAP 115's to CAP
    Posted May 24, 2014 11:40 PM
    The IAP-115 was not supported until 6.3 I believe. You'll have to upgrade to be able to convert.
  • 3.  RE: image verify failed - Conversion of IAP 115's to CAP
    Posted May 24, 2014 11:42 PM
    The IAP 115 require 6.3.x or above for conversion:  http://www.arubanetworks.com/pdf/products/DS_AP110Series.pdf
