You can delete performance data on a per-device basis from the GUI. That will be slow if you need to do it for a lot of devices though.
Do you have API access? (Either through IMC Enterprise, or with the API license). There might be an API call for deleting performance data on a per-device basis. That would make it faster for scripting.
I'd be wary of manipulating the database directly. I have done it for a few things, but not for performance data. Try taking a look at the various tables - the names are usually meaningful.
