Network Management
last person joined: 10 hours ago
IMC: Add Custom Index for temperature
  • 1.  IMC: Add Custom Index for temperature
    Posted Jul 13, 2012 07:01 PM
    I´d like to monitor the temperature of a A5800 series. Therefore I went to IMC:
    IMC   >>  Resource    >>    Global Index Settings    >>    Add Custom Index
    OID should be: 1.3.6.1.4.1.25506.2.6.1.1.1.1.12.92
    Unfortunately, I cannot get the correct "Type"
    Does anyone know the syntax for that one?
  • 2.  RE: IMC: Add Custom Index for temperature
    Posted Jan 07, 2013 12:24 AM
    With...
    Type : [index1[0]:temperature:1:0]
    Instance label: 1.3.6.1.4.1.25506.2.6.1.1.1.1.12
    ...it works for me, I can select instance 92 from the list.
    The above is hard to work with when using IRF stacks tho, I found the below makes it easier - it renames the instance numbers to the irf member IDs.
    Type: [index1[0]:StackMember:1:0]
    Instance Label (definition OID): 1.3.6.1.4.1.25506.2.91.3.1.2
    Formula:1.3.6.1.4.1.25506.2.6.1.1.1.1.12
    ... if you're interested, you can get the names of all the instances shown under 1.3.6.1.4.1.25506.2.6.1.1.1.1.12 and what they relate to, by using the entity-MIB as the instance label, as below
    Type: [index1[0]:Temperature:1:0]
    Instance Label (definition OID): 1.3.6.1.2.1.47.1.1.1.1.7
    instance 92 (1.3.6.1.4.1.25506.2.6.1.1.1.1.12.92) shows up as temperature::board - since HP A switches refer to themselves as 'boards' on the cli
