Network Management
IMC and Aruba 6000
This thread has been viewed 82 times
  • 1.  IMC and Aruba 6000
    Posted Aug 01, 2022 01:39 PM
    We are investigating if we can use the 6000-series instead of the 2530-series. I was testing administrating the 6000 switch (R8N89A) with IMC (/06P11) but it did not work very well.
    Backup Device -> Never gets finished, no file is created, no useful error message
    Import Sofware -> Dont support import software through system
    Testing SSH-Settings in IMC -> never finishes, no error message
    SSH-connection with Putty  -> Works fine
    Does imc not support the 6000 series? If yes, what settings or changes do I need to make?
  • 2.  RE: IMC and Aruba 6000
    Posted Aug 02, 2022 09:58 AM
    Hello there,
    iMC uses Restfull Api for most operations with Aruba OS -CX devices like 6000. I recommend you to use this guide to connfigure switch and iMC:
    https://asp.arubanetworks.com/downloads/documents/RmlsZTozODA0NWI0OC0wZTgyLTExZWQtODJlYy1lYjIwMmUxMGY0NmQ%3D
    Marina
    HPE
    Sofia
  • 3.  RE: IMC and Aruba 6000
    Posted Aug 03, 2022 03:51 AM
    Thank you for your suggestions. However, so far Iam getting nowhere.
    First: Is it correct that the 6000 series only features the default vrf, so everywhere the guide used the mgmt-vrf, I use the default-vrf?
    I tried using the rest settings as specified in the guide. When I test the settings, I get "Failed to test the Restful API login parameters"
    I also tried setting up the 3. party ftp server as specified in the guide. If I use the transfer mode SFTP, the config backup fails with "mode not supported". If I use the transfer mode "SFTP Server", the config backup just idles forever.
  • 4.  RE: IMC and Aruba 6000
    Posted Aug 03, 2022 06:57 AM
    Hello Walomon,
    I think that you first need to fix the Rest Api credentials. They should match in iMC and switch. On the switch check if snmp and  https server are enabled in vrf default.They might be enabled by default. Also on the switch check if  https-server has read-write access.
    The command to enable it is:  https-server rest access-mode read-write.
    If you do not use vrf mgmt, which is your case  as it is not supported on your switch than do not configure it under Service-Options as mentioned in the guide.
    Kind regards,
    Kind regards,
    Marina
    HPE
    Sofia
  • 5.  RE: IMC and Aruba 6000
    Posted Aug 03, 2022 08:22 AM
    Thank you for your continuous input.
    I used the two commands:
    https-server vrf default
    The output of the command "show https server" shows:
    "Vrf   : default
    Rest Access Mode     : read-write"
    I think that you first need to fix the Rest Api credentials. Are the Rest API credentials not the same credentials I use to log into the system? For test purposes, I used "admin" as username as well as password in the switch and in the IMC settings.
    If I go to "https://$Switch_IP$/rest", I get some JSON output.
  • 6.  RE: IMC and Aruba 6000
    Posted Aug 03, 2022 08:51 AM
    Hello Walomon,,
    Does it work to access the switch by Rest Api from iMC now?
    If not I would advise you to open a case with support.
    Marina
    HPE
    Sofia
  • 7.  RE: IMC and Aruba 6000
    Posted Jan 05, 2023 04:35 AM
    This is an old post, but I want to revive it.
    According to the documentation int the link, REST API is configured like this:
    After hours of trial and error, the only configuration I got to work, was:
    With the firmware PL.10.09.1010 I haven't been able to get any of these to work.  FYI, /api/v10.09 doesn't work either.
    Any advice to the CORRECT configuration would be welcome.
    We're currently running on IMC 7.3(E0706P11)
  • 8.  RE: IMC and Aruba 6000
    Posted Oct 16, 2023 10:21 AM
    I haven't managed to make this work as I'd expect.  The only way it the login parameters test OK is by doing something so awful it must be wrong..  If I my username was "myusernamegoeshere" and the password was "mypasswordgoeshere" the following login parameters work:
    /rest/v10.11/login?username=myusernamegoeshere&password=mypasswordgoeshere
    Surely it should be able to insert the username and password we've specified above?
  • 9.  RE: IMC and Aruba 6000
    Posted Oct 24, 2023 04:54 AM
    Upgrade to E0708P03 and this will solve a lot of your CX related issues.
    It's still not 100%, you get timeouts when performing tasks, but they actually happen around 5 minutes later
