Network Management
IMC Aruba Instant Management
  • 1.  IMC Aruba Instant Management
    Posted Dec 27, 2018 11:12 AM
    I'm trying to find a matrix for IMC, but it is hard to find and the links that I've found are broken.
    For instance:
    https://support.hpe.com/hpsc/doc/public/display?docId=mmr_sf-EN_US000005204
    We've got a customer that has many comware based devices and IMC. In which way IMC can monitor / configure an Aruba Instant (IAP) cluster?
  • 2.  RE: IMC Aruba Instant Management
    MVP GURU
    Posted Dec 28, 2018 03:54 AM
    The HPE IMC WSM (Wireless Service Manager) module is required to manage Wireless Fat/Fit APs solutions. I'm not expert in Aruba Instant management through IMC but a matrix of supported wireless devices vendors/models (APs and Controllers) can be found for sure on HPE IMC 7.3 WSM module E0506P02 Patch Release Notes (September 2018) which should be installed and licensed on latest HPE IMC 7.3 E0605P06 platform (November 2018 if I recall correctly).
  • 3.  RE: IMC Aruba Instant Management
    Posted Dec 28, 2018 08:24 AM
    Hi Parnassus,
    So I believe that the same module applies for controller-based deployments.
  • 4.  RE: IMC Aruba Instant Management
    MVP GURU
    Posted Dec 28, 2018 09:25 AM
    Yes, the HPE IMC WSM is used for managing (some, supported) controller based wireless deployments.
