Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Technical Product Details
Community Learning
News
MVP Overview
Events
Search
Discussion
Topic Thread
Network Management
Community Home
Discussion
20.8K
Library
756
Events
0
Members
999
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
IMC Automatically disable unused switchports
1.
0
Kudos
jeberhardt
Posted 4 days ago
Reply Privately
Options Dropdown
is there a possibility at IMC to automatically deactivate switch ports that have not been used for a certain period of time, e.g. 30 days, and possibly even assign them to an extra VLAN?
Thank you and best regards
Jürgen
2.
RE: IMC Automatically disable unused switchports
0
Kudos
pbit
Posted 2 days ago
Reply Privately
Options Dropdown
You can assign extra vlans or change port admin status from this Resources page, but you need to manually select the down ports. The port status is displayed when you select the interfaces.
Original Message
Original Message:
Sent: Jan 24, 2023 06:23 AM
Subject: IMC Automatically disable unused switchports
Jürgen
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2021 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
